First post, by superfury
I know that the read/write commands can specify reading or writing 1-255 bytes per sector when 0 is specified as the sector size(in byte 😎.
Now, what I want to know is how the format track command can do this? Can it format sectors with 1-255 bytes/sector?
The command bytes have some "Sector Size" byte in two places (both in the 2nd parameter and the last parameter for each sector on the track). Is there a way for them to format things like 120 bytes/sector or the like? Or any custom value between 0 and 255 bytes/sector?
UniPCemu Git repository
