First post, by LuckyPiquel
Hi Everyone!
Recently I have scored Tseng ET6000 with fully occupied MDRAM banks, as made by Hercules (my favorite version of this card, due to its kick ass Hercules logos all over the PCB 😀 I was looking for this card for a really long time (wanted Hercules with all MDRAMs soldered), however my happiness didn't last long. The picture generated by this card is far from normal (see the pictures below). After starting the computer it can give good picture, that will change into this crazy stuff after some random time (usually after 2-3 minutes), or the card is showing such problem from the start. I have also noticed that if I will wiggle it gently in PCI the picture will change as well (it can go back to normal or into other strange state). To exclude problems with the computer itself, I have tested this card on three different machines (two Socket 7 and one socket 370), with two different monitors (one LCD and one CRT). In all cases the problems are exactly the same.
To all the experts on Vogons, do you think that this card can be repaired? and what do you think can cause the problem? The card has some scratches here and there, but nothing that I can call major (please see pictures below). The only strange thing is the bracket which is bit too far from the PCB in my opinion (someone was playing with the connector ? but I cannot see any post-factory soldering job). As a result, the card sits really tightly in the PCI of any of my computers, as the bracket pushes against the back of the case.
Will be grateful for your suggestions, ideas and foremost help on how to repair this beauty! Fell free to ask for more pictures.
Would love to give this card a chance, finding another one will take me some time for sure. Thank you!
Reply 1 of 16, by Horun
Did you clean the PCI edge contacts on the card ? Use a new pink pencil eraser then use some Iso alcohol on paper towel. Also if the ROM is socketed press on it to make sure it is seated well.
Reply 2 of 16, by LuckyPiquel
Horun wrote on 2020-04-12, 22:56:
Yes I did that and repeated it today with a brand new eraser. I also checked the ROM. No luck unfortunately 🙁 card is still giving the same problems
Reply 3 of 16, by aaronkatrini
Suggestion:
- Clean the Pci connectors with some Isopropyl Alcohol (IPA)
- Blow some air into the VGA connector (preferably with a can of compressed air)
- Remove the bracket and stick the card as far in as it would go, I suspect that isn't the original bracket.
Reply 4 of 16, by Horun
aaronkatrini wrote on 2020-04-13, 22:42:
Suggestion: - Clean the Pci connectors with some Isopropyl Alcohol (IPA) - Blow some air into the VGA connector (preferably with […]
Suggestion:
Good point ! I thought about the bracket too but did some compares to others and it appears to be the right distance compared to the PCI slot edge connector though if it were not the original it could cause the front or back of the card to lift when tightened if bracket is off even a 1/16".
Reply 5 of 16, by LuckyPiquel
Suggestion:
Forgot to say, after cleaning the card, as suggested by Horun, I had the same idea so I removed the bracket and tried witout it. Still nothing changed 🙁 Althought the bracket seems to be of right lenght, even without it the card is visibly pushing against the back of the case (the thing that is pushing is vga connector). So you can imagine that with the bracket everything is even tighter. Never had such a tight card before. Surely something is wierd about this bracket/vga. I will try to completely remove the motherboard, so the card won’t be pushing against the case, and try it again.
I will also try again with compressed air and the connector itself. However, I used all my air and IPA yesterday and have to order some (cannot go to shop due to the quarantine in my country), so 1 or 2 days of waiting for me.
Reply 6 of 16, by derSammler
That's not a contact issue but more something like a bad RAM chip, which fails once heated up.
Reply 7 of 16, by LuckyPiquel
derSammler wrote on 2020-04-14, 07:47:
Good point, may be the case. Now if I will think about it... the card usually starts with a good picture (once connected after some time, so it can cool down), and starts to give problem after 2-3 minutes. If I recall correctly this does not happen when computer is just restarted, without giving card a chance to cool down.
Is it possible to check which RAM module can be the bad one? However, resoldering anything is probably not worth it. Remember Phil saying in one of his videos that MDRAMs are relatively expensive (have to check it).
Reply 8 of 16, by derSammler
You can check if one of the RAM chips is getting hotter than the others. That would be one indication of a bad chip. Another way is to use coolant spray on the chips to see if the error disappears when cooling a certain chip.
Also, I'm pretty sure the card will run with two instead of four RAM chips as well, with half of the video RAM of course. So if a chip is bad and you can identify it, downgrading the video RAM would be possible to make the card at least working correctly.
Reply 9 of 16, by Intel486dx33
looks like a software problem to me. Maybe a driver issue. Before you mess with the ram. Try the card in another computer and slot or with a clean install.
If NOT then you may need to reflow the ram and GPU chip.
It's easy with a heat gun.
Just pour some No-Clean flux on the legs of the ram and gpu chip and then heat with a heat gun to the temp of solder melt which is about 250 degrees.
heat until all the flux is evaporated. let the flux do the work of repairing any bad or broken solder welds.
Should only take about 2 minutes of heating.
But don't try to bake the card in an oven. that is a bad way of doing it.
Use a heat gun.
Solder paste should work also.
Reply 10 of 16, by LewisRaz
OP has already said they tried it in other PCs.
I agree with the heat issue. potentially point a fan at the ram chips and see if it can delay the problem?
My retro pc youtube channel
Twitter
Reply 11 of 16, by LuckyPiquel
derSammler wrote on 2020-04-14, 08:14:
Thanks for the useful tips! Now I have hope again 😀 Will try as you say today evening and share the results. This should give me some hints on the potential RAM problems. Even if I will have to desolder two RAMs, I think the same that the card should work with only half of the banks populated.
Intel486dx33 wrote on 2020-04-14, 08:42:
looks like a software problem to me. Maybe a driver issue. Before you mess with the ram. Try the card in another computer and s […]
Use a heat gun.
Thank for the suggestions on the software side, however, I have already tried to run this card in a different setups (different slots, different computers, various monitors), still the same. I also tried fresh Windows installations (both Win95 and Win98SE).
As for the reflow, I will surely include you tips in my rescue/work plan! Will remember not to bake the card 😀 Will do the reflow before potential full desoldering of any RAM banks.
LewisRaz wrote on 2020-04-14, 09:41:
Another great tip, thanks! As wrote before, today evening will do the test, before any reflowing/soldering jobs. Will share the results.
Reply 12 of 16, by Intel486dx33
Yeah, I have never seen a bad ISA video card. But have seen plenty of bad PCI video cards.
Must have been the manufacturing solder process. I assume they used bad solder or baking process as these are surface mount chips onto the PCB.
But I have a box full of bad PCI video cards I have yet to try to fix by reflowing them.
But it does work. I have fixed some already. It you have NO video it is usually the GPU chip.
If you have video but garbled then it is usually the ram chips that need the reflow.
video
https://youtu.be/ZypXa9BDXHw
video
https://youtu.be/nyele3CIs-U
Reply 13 of 16, by LuckyPiquel
Intel486dx33 wrote on 2020-04-14, 11:40:
Yeah, I have never seen a bad ISA video card. But have seen plenty of bad PCI video cards. Must have been the manufacturing sold […]
video
video
Wow, thank you for the instructive videos! I really appreciate your help. Don't think that my soldering skills will allow me to do the drag-technique 😀 but hot-air gun soldering looks like something that I can easily handle. Just have to buy proper hot-air gun for this job. From what you are saying it looks like there is still a chance for my Tseng, and I have super interesting repair project in front of me!
Reply 14 of 16, by LuckyPiquel
Just did the suggested tests on my Tseng. The outcome is: none of the RAM chips seems to be hot or hotter than the others. Also, when cooling this part of the card with fan, the problems with the card still occur. Anyhow, I have ordered hot-air gun and couple other thing to do the repair. Once done I will share the results in this thread.
Reply 15 of 16, by derSammler
For the cooling test, you need coolant spray. There's no way to do that with a fan, as a fan can not make the chip cooler. A fan only helps heat dispersion so that the chip doesn't get hotter.
Instead of coolant spray, you may also use compressed air (from a can, not a compressor). If you hold the can upside down, the liquid gas is blown out, which has the same effect as coolant spray, but it will empty the can very fast.
Reply 16 of 16, by quicknick
The fact that the symptoms change when you wiggle the card makes me think there are some bad solder joints on one of the chips. Apply pressure with your thumb on each chip ("squeeze" the card, if you will), see if anything changes on-screen while you're doing that.
