How to fix floppy diskettes ?
First post, by Intel486dx33
Is there a way to fix 3.5 floppy diskettes that will not format.
I have a couple of new boxes with these diskettes and the diskettes will not format.
The box read that the diskettes have a lifetime warranty.
100% error free ?
Reply 1 of 21, by Baoran
If you didn't know lifetime warranty doesn't mean your lifetime. It means lifetime of the product whatever the manufacturer deems it to be.
What you can do about formatting the floppies depends on what happens when you try to format them, but if you get the track 0 error you can try this software http://www.classiccmp.org/dunfield/img47321/testfdc.zip
Running it on a floppy rewrites and checks the first 5 tracks, so if it works it often allows you to use normal dos format after using it.
Reply 2 of 21, by derSammler
Degauss and give it another try.
DOS does not allow any errors on track 0, even if a sector could simply be marked as bad. There are tools to format such disks anyway, however.
Also, open the lid and rotate the disk. Look for white spots. If there are any, trash the disk and clean any disk drive you tried the disk in...
btw, these are no-name disks. Even back then, who was giving you that lifetime warranty? That's just some sh*t they wrote onto the box.
Reply 3 of 21, by zyga64
At first you may try
format a: /u
Sometimes it helps.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 4 of 21, by Intel486dx33
derSammler wrote on 2020-04-17, 06:50:
Degauss and give it another try. […]
DOS does not allow any errors on sector 0, even if it could simply mark it as bad. There are tools to format such disks anyway, however.
How can I do this at home ?
I don't have one of those machines.
https://www.youtube.com/watch?v=ybxQ2IlZOeg
Reply 5 of 21, by derSammler
Build one yourself or buy one. 😉
A strong Neodym magnet should do as well.
Reply 6 of 21, by darry
derSammler wrote on 2020-04-17, 12:06:
Magnets from a dead hard drive might be strong enough .
Reply 7 of 21, by cyclone3d
Does your floppy drive work with other disks? Even if it does, you may want to try a different drive and see if they will work.
I've got 3 different USB 3.5" floppy drives I use when imaging old disks. Some disks will work in one drive but not the others.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 21, by Intel486dx33
darry wrote on 2020-04-17, 13:28:
What is the process ?
Do you just swipe the diskette with the polarized side of the magnet ?
Do you need to swipe both sides of the diskette ?
Reply 9 of 21, by kjliew
Sorry not offering any help, but why do you still use floppy disks today?
I junked boxes of floppy disks back then in the Pentium III days and grabbed the important ones into CDs or HDDs. If you also happen to be living near the tropical with humid weather, then it make even more sense to avoid floppy disks at all cost for anything that is important to you.
Just my $0.02.
Reply 10 of 21, by derSammler
Odd question considering the focus of this forum.
But anyway, what else would you use on an e.g. 486 or earlier before the days of USB? Every retro PC should have a floppy drive. And with an USB floppy for a modern PC, it makes file transfer quite straightforward.
Reply 11 of 21, by computerguy08
If you want reliable 1.44MB file transfer for old 486s and the latter, you could use a Gotek floppy emulator.
But honestly, nothing beats the good old floppy disk. It's a challenging and fun experience (at least for me).
Reply 12 of 21, by darry
If you are going to use hard disk magnets, sandwich a disk between two and give the media a few spins using the rectangular hole on the metal hub .
That being said, I suggest you try to get some branded 3M , Maxell or Kao disks . They are much more reliable in my experience . You can still get a NOS pack of 10 for less than 20 US$ on a certain auction site, for example .
Reply 13 of 21, by kjliew
derSammler wrote on 2020-04-17, 19:12:
Well, I no longer keep any old, retro PCs around anymore. But for those PCs in that era, parallel port is almost always available, and I would use FastLynx LPT transfer. I still possess a few good quality cable today, just in case.
IBM/Lenovo Thinkpad T40 series used to have parallel port right at the back of the laptop without requiring docking. I would consider that the best intermediate option for managing data transfer with retro PCs. I even cooked up a special DOSBox with Direct Parallel Port pass-through using port-talk kernel driver from BeyondLogic. So the laptop was semi-modern with WiFi, Ethernet and USB, 2GB of RAM and run Windows XP. It can hooked up with modern servers and served as an agent for transferring data to any PCs running just plain DOS with parallel port and FastLynx, completely alleviate the need of floppy drive/disks.
Of course, one can still have modern desktop system with parallel port, but having a small laptop for such purposes is great for mobility and flexibility.
Reply 15 of 21, by maxtherabbit
kjliew wrote on 2020-04-17, 18:59:
Just my $0.02.
I still use 8" disks. There's no substitute for big disk energy
Reply 16 of 21, by kjliew
maxtherabbit wrote on 2020-04-18, 00:26:
I thought the PC history only has 5.25" and 3.5" floppy disk at consumer level. Tape-drive was enterprise equipment.
So what exactly it was for 8" disks?
Reply 17 of 21, by maxtherabbit
kjliew wrote on 2020-04-18, 01:02:
I'm not sure I understand your question. 8" floppy drives were the defacto standard for the microcomputers of the 70s running CP/M. In the 86-DOS/DOS 1/DOS 2 era, there were many OEM PC manufacturers that still used 8" drives. IBM never used them in a PC, but IBM isn't everything
Reply 18 of 21, by kjliew
maxtherabbit wrote on 2020-04-18, 04:33:
Alright, thanks. Yeah, I was too young for anything that predated the IBM PC. 😁
Reply 19 of 21, by maxtherabbit
kjliew wrote on 2020-04-18, 05:12:
I was too, but that didn't stop me from getting into the earlier stuff as an adult
