First post, by cookertron
Hi Vogons,
I bought 4 x 72Pin FPM Ram modules for my 486 (see attach motherboard). On inserting and powering up I received 2 short beeps and no post. After Re-inserting the original ram module it did the same.
The system worked fine before inserting the new ram module but hadn't been switched on for about a month.
I've since removed everything from the board except the VGA cable, keyboard, CPU and original RAM but it's not posting and giving the same beeps.
The BIOS is DragonBIOS 1993 by Phoenix Technologies.
Video of beeps in action! https://youtu.be/-MAA4eL8kUc
615.9 KiB
373.16 KiB
1.12 MiB
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 3 of 6, by derSammler
cookertron wrote on 2020-04-23, 14:57:
After the two beeps pressing F1 makes it beep again.
That makes sense, because 2 short beeps with a Phoenix BIOS are nothing serious. You should still get a picture. The "error" is probably something like "RAM size increased, press F1 to continue". Did you try a different VGA card that is known to be good? And what about the CMOS battery?
Reply 5 of 6, by LewisRaz
cookertron wrote on 2020-04-23, 15:36:
SOLVED: The monitor I've been using for that machine was using the DVI input FFS!
Oh 😁
We have all done it. Not all as publicly as this 😀
Glad its working.
My retro pc youtube channel
Twitter
