First post, by brian105
I tried to play Quake II on my system with the ATI card, which didn't go very well. Software mode works, even with the 3dnow patch, but every single time I choose OpenGL and the game restarts to apply the setting, it just reverts to software mode. To make sure it wasn't the game itself, I tried it on a machine which is muuuuuuuuch newer, and OpenGL worked without an issue.
I tried 3 different drivers: one mobility driver (M6_12_12), the latest desktop driver (J5-30-1-b02) and a custom driver with a filename of W82560en. All drivers exhibit the same issue.
One other slight issue is the lack of 16:10 resolutions (obvious for drivers from this era). https://www.oocities.org/ziyadhosein/inf.htm describes how to set up custom resolutions, but after I edited the .inf and installed the driver via device manager, it didn't let me choose the custom resolutions.
Anybody who knows these iGPUs (or I guess relabeled laptop GPUs) well, please help!
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 1 of 3, by appiah4
Set desktop color depth to 16-bit and it will work. Known driver bug.
Reply 2 of 3, by brian105
Yep, that seemed to work immediately, thanks! This iGPU is actually a very decent performer, about 25fps on the texture quality setting set to the 2nd-rightmost option.
Reply 3 of 3, by appiah4
brian105 wrote on 2020-04-26, 05:32:
I have a 4MB Rage Pro and yes I need to lower texture quality a notch for better gameplay. Using 8-bit textures does not seem to help much though..
