First post, by KitsuneFoxy
Hi, I've dug out an old Super I/O card, It is an ISA card, with no manufacturer markings, or anything of the sort. I cannot find anything but the datasheet.. and i am not technically minded enough to understand it to know what jumpers are which. And any sort of manuals i have found are for the W837871F. Which has a completely different layout on the cards i've looked at. I really am at a full loss.
I've included some pictures of the card itself. There is nothing on the back besides some date of 2001.
It came with an extension for two extra com ports.
I've looked on Statson.org and he doesnt have it either. I've googled a lot of images, and can't find one like this.
All i can find about it is this https://html.alldatasheet.com/html-pdf/47764/ … 1/W83787IF.html
Thank you for any and all help.
Reply 1 of 1, by jmabrra78
Hi,
I recently get the same I/O card and this is the jumper config:
JP2 PTR PORT EN/DIS ENABLE DISABEL
JP3 SIO 0 PORT SELECT COM1 COM3
JP4 FDC EN/DIS ENABLE DISABLE
JP5 SIO 1 EN/DIS ENABLE DISABLE
JP6 PRINTER PORT SELECT 0378 0278
JP7 SIO 1 PORT SELECT COM2 COM4
JP8 GAME PORT EN/DIS ENABLE DISABLE
JP9 SIO 0 EN/DIS ENABLE DISABLE
JP10 IDE EN/DIS ENABLE DISABLE
JP11 IRQ 3 SIO 1 SIO 2
JP12 IRQ 4 SIO 1 SIO 2
JP13 IRQ 5 SIO 1 SIO 2
JP14 IRQ 2 SIO 1 SIO 2
JP15 PRINTER IRQ SELECT IRQ 7 IRQ 5
Attach a picture with my setting
It works for me all except Floppy drive, but I think there is an issue with my motherboard because the controller card works fine in other one
I hope it helps you
    58.29 KiB
