First post, by TheAbandonwareGuy
- Oldbie
Hey there,
I'm starting this thread as I feel its time to start compiling data on different models of high performance/dedicated gaming laptops from the 2000-2006 era. I feel like there is a lack of available comparitive data available. Anyone is welcome to submit results provided they include the following 3 benchmarks at a minimum, and specify the following information.
* 3DMark2003
* 3DMark2005
* 3DMark2006
Exclusions apply in cases of lack of support. For example you obviously don't need to run 3DMark06 on a SM2.0 capable GPU. You can also supply additional benchmarks if you so choose such as AquaMark or Unigine.
Please specify the following:
* Laptop Manufacturer:
* Laptop Model:
* Installed Processor:
* Installed Graphics Processor:
* Installed Memory:
* Installed Hard Drive Type/Capacity:
* Screen Resolution:
Please use the format provided in my second post. I will be benchmarking all my laptops and adding them here as time allows.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
