First post, by vtgearhead
I'm fiddling with an old Poquet PC that came with two Verbatim 1MB (!) PC cards (battery backup). Since I do not have the proprietary expansion cable there's no way to get a serial or network connection to the unit for moving files back and forth. Plan B is to access the PC cards from another system that has PCMCIA slots. Unfortunately, I'm having difficulty finding drivers for, e.g. my Windows 7 laptop. It recognizes the card, but fails driver search. I do have an older IBM Thinkpad 365 that runs Windows NT and DOS. Anyone know where I can find drivers for either of those environments? I keep tripping over documentation and discussion of Cardsoft driver packages, but cannot seem to locate any downloads.
Reply 1 of 5, by derSammler
Tried myself to use SRAM cards in DOS, Win3.x, and Win9x with no success. Even when recognized, they would not appear as a drive. I still have my SRAM cards and PCMCIA reader, so I'm interested in this as well.
Reply 2 of 5, by my03
Hmmm. I'm fairly certain that i managed to recognize and use an 8MB ram card (Intel) on my Windows 7 laptop. Let me dig it up and retry it, perhaps i can give some input (hopefully).
I also have another brand of linear flash (i think it was a 6MB AMD and one 4MB that i will test).
Reply 3 of 5, by derSammler
SRAM and Flash cards are two different things. Flash cards work fine, at least they did for me even in DOS.
Reply 4 of 5, by my03
you are right. I misunderstood the op
Reply 5 of 5, by vtgearhead
Interestingly, WinNT with CardWizard (finally found a copy on Dell's website) recognized the card and was able to format it as a disk drive. However, the card became smoking hot (voltage too high?) and the format was not recognized by the Poquet PC. Fortunately neither the card nor my ancient ThinkPad were damaged.
