First post, by Almoststew1990
- Oldbie
I picked up an 800MHz Slot 1 CPU that I am hoping to use to upgrade my 650MHz system.
The 650MHz CPU has an easy to use cooler and I put a modern fan on it.
The 800MHz CPU has one of these....
Can I put the 650MHz cooler on the 800MHz CPU? And will the black 800MHz cooler fit on the 650MHz cooler (so I can sell it on)? I thought I'd check before I probably break the black heatsink...
