First post, by SimonV
Suddeny my ESS Audiodrive starts to make scratching / cracking sounds instead of giving me Soundblaster SFX. Well I still do here Soundblaster SFX but the scratching has the upper hand. I understood genuine soundblasters could have this problem but an ESS ? It happened after reinstalling my 486slc machine. I have a dreamblaster on the card that works fine at the same time in Doom. It also happens with the SFX in Dune2 / sampled sfx . Adlib in Prince sounds fine.
People suggest it's an IRQ problem so I disabled the IDE of the ESS card, tried both IRQ 5 and 7 with both DMA 0 and 1 . Other DMA channels result in no SFX at all and a single time ( 1 out of 40 reboots ) it actually works like intended.
I am kind of out of ideas.
Reply 1 of 2, by TechieDude
I assume it worked before you reinstalled it. Is there anything you have done differently from the previous time? Have you tried it without the Dreamblaster (unlikely to be cause, but you never know)?
Reply 2 of 2, by SimonV
Well I solved it by swapping the order of the vga and soundcard. So i guess it was indeed an irq problem.
