First post, by egbertjan
I have a shuttle AV18E2 motherboard and the white ide connetor gives the following error no 80 pin conductor cable installed. I have already used several 80 pin ID cables, but nothing helps to get the message out. The hard drives that I connect to the white ide port are also very slow due to this message. The other blue ide port is working fine.
867.24 KiB
Who knows what I can do to fix this or is the motherboard broken?
I would like to use that motherboard to install Windows 98se to play old games.
Reply 2 of 2, by Kahenraz
I have the same problem with my Shuttle HOT-675V motherboard. I know that all of the capacitors are good because I replaced them all myself with genuine Nichicons.
This is super annoying.
I tried shorting pin 34 to ground manually but it didn't make a difference. In this case I used a CF adapter but the error is the same on a regular hard drive. The pin is just easier to access here on the adapter.
1.86 MiB
