First post, by 386_serlaptop
Hey guys! New to the forums but I'm hoping you guys can help me.
I acquired this seemingly generic i386 laptop a while ago, and the only issue it seems to have is the keyboard. When I use an external keyboard the error goes away. If i unplug the internal one, same issue. Any ideas? I had a hard time finding any information to help me here
Thank you in advance!!
The attachment IMG_2295.JPG is no longer available
The attachment IMG_2294.JPG is no longer available
The attachment IMG_2293.JPG is no longer available
The attachment IMG_2292.JPG is no longer available
Reply 1 of 2, by Horun
On those "slide in" ribbon cables, gentle remove one at a time and clean the edge contacts with Iso alcohol on a paper towel. Make sure you mark one side of cable and connector before removing so you get it back in the proper way.
Reply 2 of 2, by 386_serlaptop
Hey! Thanks for your quick reply and help. However, the issue was not fixed. Anything else to try?
