First post, by jennifer3
jennifer3
Offline
First of all, it's been 5 years since I was on this forum, and I wasn't sure where to post this; so if I've put this post in the wrong place, I'm sorry.
Anyway, I'm playing an old game, 3D Frog Frenzy, where you get to control the direction the frog hops, around obstacles and hopefully to the goal. On the first level, you supposedly get 3 minutes to solve the level, but the timer runs much too quickly. Instead of 3 minutes, you only get 1 min 48 sec. (Not so bad in the first level, as the time alloted is bloated for beginners, but in later levels I'm barely making it through the maze with no more than a few seconds to spare.
Is there some known issue with time running too fast? My configuration is in the subject line above.
Jennifer
