First post, by Nexxen
Hello everyone!
I'm looking to update the bios of my PcChips M530, but I cannot find a file that I'm 100% sure will work.
Some have this board, maybe you can help.
This is my Bios version:
10/20/1996S
10/18/96-i430vx-10031996c-oo
Bios is 131kb. If needed I can upload it.
I don't know which tool to use to open the bin file to find more info. Any suggestion appreciated.
Thanks
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 46, by Deksor
Here's one from 1998.
It's for the m520 but it says right here http://www.elhvb.com/mobokive/Archive/PcChips … M539/index.html that the M530 uses the same bios (they both use the same chipset afterall)
This page also leads to the same BIOS http://www.elhvb.com/webhq/models/pcchips/m530.htm
Reply 3 of 46, by Deksor
The only website I know for this is this one http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
and it hasn't K6-2+ mod 🙁
But maybe there's one elsewhere ?
Also maybe you can improve things using this ? http://www.win3x.org/win3board/viewtopic.php? … =188943#p188943
Reply 4 of 46, by rmay635703
Deksor wrote on 2020-05-05, 00:26:
The only website I know for this is this one http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm and it hasn't K6-2+ mod :( […]
If Jan still exists email for it, I’m guessing no one validated that the bios update worked and it didn’t get published
Reply 5 of 46, by Nexxen
I feel less than a noob when I can't find info like this 😒
Thanks!
Reply 6 of 46, by Nexxen
Faut vraiment que j'apprenne à chercher...
So, I could always patch the bios by myself or the tool requires really deep knowledge beforehand?
Reply 7 of 46, by Deksor
Non, c'est facile 😀
You just need to unzip the archive, and run the .exe with your rom file's path as parameter and it'll patch the bios automatically.
I can't guarantee it'll make a working bios though but so far I didn't have any issues.
Reply 8 of 46, by Nexxen
Flashed all the versions here,
Unicore version has a BIOS password, and W98SE freezes - but pc boots and might work if reinstalled. Not tried anything to verify.
1997S - same issues - probably 98SE needs some fine tuning.
I get XMS error and after the first splash screen - with corrupted colors - hangs in a way or the other
no password
Edit: ended up playing Quake 2 with Voodoo2... This stuff is addictive 😀
Reply 10 of 46, by Nexxen
Deksor wrote on 2021-01-04, 21:36:
For the unicore bios, try the password "otrebla" ? The archive was protected by that password so maybe the bios itself is using the same password ?
I'll try that but I'm more on the "patch it" direction.
Gonna get more HD support and I have no issues apart from that.
Thanks and happy 2021!
Btw I made a few posts on boards you don't have in database. Look me up and take what you need.
Reply 11 of 46, by 001
I actually have the Unicore bios in my M520. It has the 32gb bug, but it does detect my K6-2+ fine (I'm using a poweleap). So yeah, probably best to patch according to your needs.
Did you end up patching your bios? How did it go?
Reply 12 of 46, by Nexxen
001 wrote on 2021-01-05, 03:58:
Haven't yet.
I need to put it on the gotek. Gonna do one of these days.
I had it already patched on the HD I accidentally formatted with all my archive of mobos 🙁
I understand what a failed drive means on a 0 RAID 😀
You must use a powerleap, no native support. That's already something.
Reply 13 of 46, by 001
@Nexxen, what do you use for storage in that mobo? I'been thinking in ditching the old ide drives for something more current. Maybe a SD to Ide + a Toshiba FlashAir, so I can share folders via integrated wifi in the card, faster than by ethernet.
Reply 14 of 46, by Nexxen
001 wrote on 2021-01-07, 03:54:
I use IDE drives because without LAN, antivirus and firewall it's quite fast.
I have WIn98SE with all updates and SPs.
Works nice and I don't think I'm going to use any other device, not that it wouldn't be a good option if only to transfer files.
I have a rack to move and remove an hd for file transfer, dual/triple/quad boot, but it doesn't happen much as with usb, even @ 8mbit it's usually enough for everything like mounting a cd image.
Never used a flashair but that's a thing I have to learn.
Edit: I have a USB 2.0 pci card in.
Reply 15 of 46, by 001
I use the usb headers in the motherboard. It's slow, USB 1, but gets the job done.
Reply 16 of 46, by Nexxen
I patched the Bios but there is no difference with supported HD size.
Probably the patch didn't work. I still have a beta and an alpha patch executables to try.
Or just running the patch isn't enough. System works well as is and I'm in no 1999 need of a bigger hard drive 😀
Reply 17 of 46, by nickles rust
Hello, I found this thread while looking for a bios to run a K6-3+ in one of these boards. I saw that Jan has one on his web site for the M520. I can try this on the M530, but I was hoping to confirm before trying because I don't have an EEPROM programmer to revert if it doesn't work. Thanks!
Reply 18 of 46, by nickles rust
I tried to attach the original bios file. I added .jpg so the forum would take it...
Reply 19 of 46, by nickles rust
Maybe .zip works?
