What games for a 286-6
First post, by candle_86
So I'm buying a 286-6 machine from a local guy, I wasn't using 286 back in the day, I started with my parents ibm 266pr cyrix so early did games I never really played. I plan to change that now. What games should I hunt down or grab from steam/gog and copy the games from.
Not sure what games are optimal but I know the dos games I did play like black night, SimCity 2000, Doom, wolf 3d, cnc, and colonization ate to new.
Reply 1 of 20, by Horun
The original side scroll Duke Nukem's, Commander Keen, most of the old side scrolling Apogee games, etc. You will not be able to play any of the early 3d games Like Doom, Heretic, etc on a 286-6 even if you have a good ISA VGA card.
edit: Check Moby Games, they list games by processor, here are some for 286:
https://www.mobygames.com/attribute/sheet/att … ibuteId,65/p,2/
added: you can DL the Apogee shareware versions of their games here: https://www.dosgamesarchive.com/profile/apogee-software/
and you can search their site for others too, many can be downloaded free....
Reply 2 of 20, by kolderman
80s games. Early Sierra titles in EGA. Gold Box d&d games. Text adventures (Zorks). Most of your games are mid 90s and will not run.
Reply 3 of 20, by xjas
Any of the Freescape games if you want a first-person experience in a true 3D engine with a fully explorable environment. Space Station Oblivion (my personal favorite), Dark Side (its sequel), Total Eclipse, Castle Master I & II, etc. They might be a bit pokey at 6MHz but they'll run. Print out the controls & a map, and make sure you know what you're supposed to do before you start as it's not explained in-game.
For a simpler arcadey title, Alley Cat is still good fun.
Reply 4 of 20, by dr.zeissler
i can make you a dir of my a2286/8
Reply 5 of 20, by candle_86
kolderman wrote on 2020-05-05, 02:54:
Will all 80s games run? What about the original wasteland?
Reply 6 of 20, by derSammler
Unfortunately, a 6 MHz 286 is more limited to games than even an XT. Most games made for the PC/XT will run, except those that have their speed fixed to 4.77 MHz. They become unplayable fast. For anything past the XT era, 6 MHz is too slow. My slowest 286 has 10 MHz and even that is pretty much useless. There are a few EGA games it will run at good speed, but you really want to have at least 16 MHz.
Reply 7 of 20, by Baoran
candle_86 wrote on 2020-05-05, 12:01:
Original wasteland will work fine. Also ultima 1-5 should work fine too.
Reply 8 of 20, by candle_86
Ok XT class games, I know this computer has a VGA card
Reply 9 of 20, by radiounix
It should do well running mid-late 80s EGA games. These were usually no longer terribly speed sensitive, and would load with varying degrees of playability on a Turbo XT. Most should be playable given a 286/6 is probably about twice as fast as the 8mhz 8088 people tended to own.
VGA games, 1990 on, were really for faster 286s and 386sx machines. More like a 286/10.
Reply 10 of 20, by rmay635703
Kens Labrynth isn’t optimal but it pushes limits.
The original flight sim and many 80’s games will run fine.
Some 4.77mhz locked games will be too fast but on a system that slow the original mo’slo actually works properly to fix it.
You have yourself an XT+ system, most anything XT will run into there and a lot of newer games are fine even if a little slow.
Reply 11 of 20, by keenmaster486
You could even run Wolfenstein 3D on it but it will be absurdly slow.
I know because I've tried 🤣.
World's foremost 486 enjoyer.
Reply 12 of 20, by candle_86
Nah I'll stick to wolf on my Pentium
Reply 13 of 20, by xjas
^^ the Freescape games run a far more advanced engine than Wolf3D, and will run considerably faster on your machine. Just saying. :p
I actually fired up an emulated 286/6 last night & tried out SSO and Castle Master. Was pretty impressed with how well they did. Not 60FPS (or even 30), but fully playable. The Hercules graphics mode looked pretty neat, too (of course C/E/VGA also work.) Seriously, give 'em a try.
Reply 14 of 20, by douglar
I played the snot out of "Empire: Wargame of the Century" and "Prince of Persia" back in the day.. I think you are good for those @ 6mhz.
I'd recommend "Railroad Tycoon" but that probably needs more than 6 mhz.
Reply 15 of 20, by candle_86
Wrong on CPU speed it's 12mhz and turbo makes it 6mhz. If that makes a difference
Reply 16 of 20, by rmay635703
candle_86 wrote on 2020-05-07, 19:38:
I played Wolf 3D on a 10mhz Tandy 1000rlx and was satisfied in the day.
12mhz will run most anything 286 “good” per the standards of the day.
Reply 17 of 20, by Horun
I think you meant: 12mhz cpu at 6mhz and turbo makes it 12 mhz. Or did I misunderstand.
Reply 18 of 20, by nismotigerwvu
Thaaaaaaat makes a lot more sense now. Small (somewhat related) tangent for anyone who might know, how exactly do those 6 mhz 286's (if any still exist, I know they were rare even back then) or Turbo'd down models operating at 6 mhz handle the ISA bus? Do they just bring it down in lockstep? As far as I can remember, it wasn't until at least the 386 that they split the clock planes in that regard.
Reply 19 of 20, by BinaryDemon
Prince of Persia
Battletech: The Crescent Hawks Inception
Life and Death
I remember playing the Adventures of Willy Beamish and Star Control on a 286 as well, but it was probably a beefier machine.
