First post, by speedwarrior911
speedwarrior911
Offline
- Newbie
I was wondering if somebody else got this error message after running the game from the offline launcher on Windows 10:
"Process failed with return code -1073740771. Error #0."
It happened after doing some drag racing matches with the '70 Mustang Mach 1, which is kind of weird as I've set it to run in Windows XP SP3 compatibility with administrative rights enabled. It happened previously after a couple of aborted test drives in the same car on the Roadkill stage. I hope there's a fix to this as well as a proper widescreen patch for it to enjoy it as much as my other driving games.
Your help will be greatly appreciated
Greetings
