First post, by weirdah
Hi!
I have some Olivetti old school PCs trying to fix. The first one is an Olivetti M4 65 Modulo. The problem with this unit seems to be the power supply. The PC components seem to work for a few seconds after turning on the PSU, after 3-4 seconds power goes down. If I try it for some more times, PSU powers for some more seconds, so I was able to get the boot screen once.
If I start the PSU without load, it works fine. Voltage is stable and values are near what they are suppose to be:
Black - Ground
Black - Ground
Black - Ground
Orange - 12,38v
Yellow - -11v
White - 5,32v
Red - 5,32v
Red - 5,32v
Red - 5,32v
Red - 5,32v
Black - Ground
Black - Ground
PSU seems to be preety good visually, I cleaned some dust with a soft brush, I've not cleaned any corrosion or something similar.
Could you help me to reach the problem?
Thank you all!
