First post, by Ozzuneoj
- l33t
EDIT: Herp derp... problem solved. Move along... nothing to see here. 🤣
I'll try to get a picture of this later but I figured I'd just toss the question out real quick. I've posted about this in other threads but I'm still stumped so I decided to make a thread for it.
I have an odd problem with a Canopus Total3D Verite 1000-L, but only when using a CRT. When I start Windows 98SE with the command prompt or restart in DOS mode, everything looks normal but as soon as I hit enter to cause the screen to scroll up a line, the bottom line of text (the line I type on) will disappear. After it has done this, there is nothing visible while I type. Hitting enter shifts everything up a line again as normal and I can see the command I typed, but the new prompt is still invisible. It isn't a screen alignment issue because it shows that line until the first time it scrolls. It's like using the card on a CRT sets DOS to "Hardcore Mode" so that you can't see what you're typing until you hit enter. 🤣
The crazy thing is, I tried the same card in the same computer on two LCDs (a 1280x1024 Dell and a 1024x768 Viewsonic) and they show all text totally normally! I hooked it back up to my big beautiful 21" CRT and the problem was back. The CRT monitor is reporting the vertical refresh rate as 70.9HZ. When I hook it up to one of my LCDs it says 720x400 at 71Hz. Is it possible that this is some really oddly specific refresh rate issue? I can push the card to what are relatively crazy resolutions and refresh rates for 1996 (1024x768 at 100Hz) and it works fine. It uses a Brooktree RAMDAC, but I've never seen an issue like this with one before, or any other card for that matter.
Any suggestions would be greatly appreciated.
If pictures would help, let me know.
