First post, by CHiLL72
Recently I bought a Super Socket 7 mainboard, an EPOX EP58-MVP3C-M rev 1.0. It came with a Pentium MMX 233MHz CPU and 128MB SDRAM. It has a BIOS dated 07/10/1998. According to the manual, it does not support AMD K6-2 CPUs out of the box (only K5/K6), but according to information I found, this should be feasible with a BIOS update. There are not many resources available online, but I downloaded the BIOS for my mainboard from this page: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
I suppose this BIOS version has been modified, but I was unable to find any other versions. This BIOS is exactly the same as the one posted on Vogonsdrivers.
I unpacked it onto a floppy disk and ran the update, which appeared to go just fine. The BIOS IDs matched and AWDFLASH showed the flash was successful. However, I could not get the system to boot at all. No beep, nothing. Black screen, just the CPU fan spinning.
During the BIOS update, a copy of the old BIOS was written to the disk and using the 'hot flash' method on another mainboard, I was able to restore the original BIOS. And sure enough, the system booted fine again.
Just out of curiosity, I put in an AMD K6-2 333MHz CPU, but the system would just beep and not boot. Putting the Pentium MMX back in restored the system to working order.
I am unable to figure out why the updated BIOS does not work on my mainboard. Does anyone have another BIOS version that may work with AMD K6-2 CPUs on this mainboard?
One thing I did not try, is flashing the updated BIOS using UNIFLASH, either with or without updating the boot block. Could that make any difference?
The images attached show some info from both the original and the updated BIOS and to me it looks like these are for the same mainboard.
Any help would be appreciated. Otherwise I will start looking for another mainboard.
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 1 of 23, by evasive
Did you reset the bios to defaults before and after flashing? Sometimes settings already made in the bios are not there or in a different location in the new one. I know it should not matter but somehow sometimes it does.
Reply 2 of 23, by CHiLL72
Taking out the battery and leaving the board without power should do that also. And yes, I tried that. After flashing nothing works, besided the CPU fan spinning. No beeps, no video signal, nothing....
Reply 6 of 23, by CHiLL72
I just had a little time to try this BIOS on my mainboard. And yes, success! Thank you Doornkaat!
After flashing, I rebooted the system and it worked. I now have a BIOS that is more than a year newer than the version that was originally on it. I have yet to test if it now supports AMD K6-2 CPUs. That was not mentioned in the release notes for the BIOS. Does anybody if it should?
Reply 7 of 23, by Doornkaat
Happy to help! 😀 I don't know wether this BIOS supports the latest K6-2(+) K6-III(+) though. Sorry.
I dug up another image of the latest BIOS. Would you care to try it to help determine wether the one hosted by Jan Steunebrink may be corrupted?
Edit: Misread your post, I'm very optimistic a 1999 BIOS for this board will have support for K6-2 processors. 😀
Edit 2: Found this in the manual (also attatched):
(only version 1.0 or above does support processor of 400/450MHzAMD K6-2/3)
You should be fine! 😁
    58mvp3c.pdf
    209.77 KiB
    53 downloads
    vp300411.exe
    160.42 KiB
    75 downloads
Reply 8 of 23, by PC Hoarder Patrol
Copied this text off the Epox archive pages - seems to have had K6-2 support from early on
149.22 KiB
This (live) archive link also seems to be a later revision than vp300411
https://web.archive.org/web/20021126111852/ht … ios/socket7.htm
Reply 9 of 23, by CHiLL72
Thank you both for digging up the extra information. Looks like I will be trying a K6-2 in this mainboard. It appears that I am lucky to have a revision 1.0 board and that support for K6-2 CPUs was added after the date the original BIOS on my mainboard had. I hope to find out some time tomorrow.....
Reply 10 of 23, by CHiLL72
Well, I tried a few AMD K6-2 CPUs today, but they don't work. I changed the jumper setting for the Vcore to 2.2V and set the jumpers for bus speed and multiplier, but all the board does is beep at me.... A long, semi-continuous beep. And as I do not have AMD K6 (or even K5) CPUs, I cannot test those. All I have is number of Pentium and Pentium MMX CPUs (which do work) and about a dozen K6-2 CPUs, ranging from 333MHz to 500MHz. I did not try all of them, but the ones I tried all gave the same result. And when I switch back to an Intel CPU, all is fine. Hmmm.
One thing I did not mention before, is that one of the capacitors near the CPU appears to have been replaced. But apparently that does not matter for the Intel CPUs.
Reply 11 of 23, by Daniël Oosterhuis
On my Epox EP58-MVP3C-M, using that 2000 BIOS, my K6-3D 233AFR (early K6-2) does work. However, mine is a patched version from Wimsbios, to support 128GB HDDs, so I have no idea if this has also been patched to support K6-2 CPUs. I'll attach it. If this doesn't work, it might still be a hardware incompatibility on your board.
    epox.zip
    111.95 KiB
    54 downloads
Reply 12 of 23, by evasive
The newer bios can be patched if wanted. Just say when.
the later bios mentioned on that archive link is a 2Mbit variety, I think it's for even later revisions of the MVP3C
Reply 13 of 23, by PC Hoarder Patrol
Weird that it doesn't work with al least one of the bios revisions listed - what are the specs of the chips you did try (any pics). Maybe it's an issue with processor cores (Chomper vs Chomper XT)
Reply 15 of 23, by CHiLL72
Finally I got round to taking some pictures of the area around the CPU socket.
One capacitor is clearly different from the others and it has been soldered in later.
Reply 16 of 23, by LHN91
Yeah that should definitely support K6-2's - I have the identical board on the shelf next to me with a 500 Mhz K6-2 installed.
I'd have to put it in a case to test it for sure but I'm pretty confident I ran it this way, the jumpers are all set appropriately.
Edit: And yes, that one capacitor is clearly different than the one on my board as well.
Edit-er: And I also just noticed that you've got the board set to 2.8V right now - what CPU do you have installed?
Reply 19 of 23, by candle_86
I use the bios from this page, it adds k6+ support and it works, make sure your getting the mvp3c-m
