First post, by keenmaster486
My PC/AT originally came with a Model F keyboard. I've been using it with that since I got it.
But I also own a Model M keyboard, from the PS/2 era. I have a PS/2 to AT adapter so I thought what the heck, I'll try hooking this up to the AT.
So far it works great, with one exception.
The arrow keys work strangely. You cannot use them in combination with the "home", "end", etc. keys to highlight text. And you cannot use them to navigate back through text you've typed in the command line, as the left arrow acts the same as the backspace key.
But if I use the arrow keys and "home", "end", etc. keys in the numpad, *then* it works.
What gives? Is there some incompatibility I didn't know about here?
World's foremost 486 enjoyer.
Reply 1 of 4, by pentiumspeed
Do a pull up resistors mod on the clock and data line inside the keyboard.
Cheers,
Great Northern aka Canada.
Reply 2 of 4, by locus
Maybe the BIOS is too old for the Model M ( doesn't support the newer scancodes ) ?
see : Here and Here
Reply 3 of 4, by keenmaster486
pentiumspeed wrote on 2020-05-11, 18:16:
What exactly do you mean by this? I cannot find any information about this mod on the web.
locus wrote on 2020-05-11, 18:28:
Perhaps. But I don't necessarily want to modify my BIOS as it is the original one.
