IMGMOUNT in Linux
First post, by Grunt
Hello, guys.
I am confused:
15 KiB
I can mount Floppy Image without problem but device is marked as directory. Why? Is this OS bug?
Reply 3 of 20, by Caluser2000
Grunt wrote on 2020-05-11, 17:51:
Hello, guys. I am confused: imgmount.png […]
Hello, guys.
I am confused:
First you need to understand how linux, or for that matter *nix workalike OSs, functions then you will have found the answer to this question. Any old *nix book will do.
Reply 4 of 20, by Grunt
Caluser2000 wrote on 2020-05-11, 18:08:
Now I'm confused even more. Should I try loop device?
Reply 5 of 20, by gdjacobs
Grunt wrote on 2020-05-11, 18:04:
But /dev/sdb isn't directory. It is file.
/dev/sdb is a file pointing to a device
Reply 7 of 20, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Ok, just to take a shortcut, imgmount is for image files that are not mounted by your OS.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 20, by Grunt
Which is exactly what I want. /dev/sdb is floppy device. I don't want to use system mounting because caching, I want direct mount from Dosbox.
dd if=/dev/sdb of=/tmp/image.img works perfectly. IMGMOUNT /dev/sdb - file is not a file but directory. What?
Reply 9 of 20, by Dominus
DOSBox Moderator
It's a floppy DEVICE not an IMAGE. IMGMOUNT is for IMAGES. NOT for devices.
The dd command makes an image of the device which, as it is now an image, of course works.
Try
Mount a /dev/sdb -t floppy
Reply 12 of 20, by Grunt
jmarsh wrote on 2020-05-11, 18:50:
You can only imgmount regular files, not devices.
Oh, thanks. That is explenation. Ok and equivalent of MOUNT A A: -t floppy in Linux exists?
Reply 14 of 20, by Grunt
So short answer: No, no equivalent for direct manipulation with device.
Why it is problem? Work with block device is just as work with regular file. Seeking, reading, writing. It should work. It is safe just to comment checking macro?
Reply 15 of 20, by jmarsh
It's not the same. Block devices have stricter requirements regarding read/write sizes and offsets, may require explicit seeks... there's no guarantee the C library will take care of that correctly if you use the buffered I/O functions (which DOSBox does).
Reply 16 of 20, by Caluser2000
I thought fd0 was the block device for floppies. Not that I'm an expert or anything...
Reply 17 of 20, by Grunt
jmarsh wrote on 2020-05-11, 19:24:
Hmm. There should be warning in DOSBox Wiki or something. First thing I'm going to do when I pull out the old rusty harddrive/FDD is to IMGMOUNT it Linux. Just to be safe.
And you know what? It quite sucks. There is plenty of tool for Windows but just mount.vfat for Linux. Shouldn't be at least loop device (img)mountable?
Caluser2000 wrote on 2020-05-11, 19:26:
It is. If you own FDC. I have SCSI device so it is under /dev/sdX.
Reply 18 of 20, by jmarsh
Grunt wrote on 2020-05-12, 18:28:
That's not safe at all. The safest thing to do is make an image and mount a copy to keep the original data pristine.
You can't imgmount a physical floppy drive under windows either. You can only mount the drive letter as a directory, which is the same as under linux; accessing the underlying filesystem is handled by the OS in both cases.
Reply 19 of 20, by _Rob
Normally on linux the floppy drive would be /dev/fd0 and is a so-called "block device". It should not be too difficult to implement support for it in DOSBox, but nobody has until now, and considering how rare such setups are nowadays means it probably never will. The openMSX emulator for instance can directly access a floppy drive on Linux.
Your however using /dev/sdb, which to me means it is not a real floppy drive. But probably a USB Floppy Drive, which uses a completely different protocol called UFI. Under Linux you have for instance "ufiformat" for formatting a diskette in a USB floppy drive. You can also query the supported formats as follows (with a 720kB DD disk in the drive):
sudo ufiformat -i /dev/sdb
vendor: TEAC
product: FD-05PUB
write protect: off
media type: 2DD
status block size kb
formatted 1440 512 720
formattable 1440 512 720
