First post, by Element81
- Newbie
Long time lurker here and officially a new member. I've been collecting retro hardware for many years and I frequent this site for general information. I've been PC gaming since 1993 and building systems since 1999, so I have a bit of experience under my belt.
I'm looking to build a new Windows 98SE computer and I'd like to hear some opinions on what chipset I should use as the foundation. I've decided to do an Athlon XP build because I don't have a functional Athlon system currently. I'm considering either the VIA KT600 or 400A, or the nForce2 and I'd pair it with a mid-range Athlon XP CPU. The reason I'm looking at these chipsets is because I'd like the following features: SATA, USB 2.0, and the 12V CPU power connector. As far as I'm aware, this combination of features is only available on the later Athlon XP chipsets. I'm not planning to use any Voodoo cards, so I'm not concerned with the lack of 3.3V AGP. I'd most likely use a Geforce FX 5900 as the GPU. Lastly, I will probably dual boot Windows XP on this machine.
I've got experience with the nForce2 chipset and it's never given me any trouble, but I'm looking at the VIA KT400A or KT600 because I've never done a build with VIA before. Is there any particular reason I should stay away from VIA for a Windows 98SE build and just stick with the tried and true nForce2?
I appreciate the input.
There is no cow level.
