First post, by Planet-Dune
I am trying to run dos games in windows (so not while booting in real dos mode). The games mostly work fine except music. In the vast majority the sound effects are no problem but the music does not play.. I did not do anything except install the win 98 drivers and run the sound setup file if present for the game. For the sake of making my life easier I am content with just running the games in windows but woyld like music (I asssume the problem is midi? Not sure...).
Reply 1 of 1, by leileilol
Select "General MIDI" where possible if you want the best possible choice of music from that card. There's no OPL2/3 chip on it, so the usual adlib tunes would require loading a TSR that 'emulates' it horribly (though.....it can be a guilty pleasure), and this TSR is provided by EnsoniqCreative's driver installer.
long live PCem
Debian's fucked
