First post, by Holovox
I'm working on putting together a PC using parts mainly salvaged from a Packard Bell from around 2000. I bought the motherboard new old stock to replace the one from the Packard Bell as it had bulging/leaking capacitors. I hoped I wouldn't encounter issues with a fresh board, but that doesn't seem to be the case. The board is clean and all capacitors look to be in good shape from visual inspection. I've been having issues getting the PC to boot so have thinned down to the fewest and most basic parts necessary to try to eliminate parts. (I'm planning to upgrade when I can actually boot). Spec is as follows:
MSI MS-6309 Lite
733MHz Pentium III (SL3XY) (Socket 370)
128MB PC133 CL3 SDRAM
nVidia Riva TNT2 Pro 32MB (Leadtek Winfast branded)
Mitsumi 3.5" floppy drive
(All parts (CPU, RAM, AGP, floppy) except for motherboard have been tested in other rigs and have been swapped out multiple times with known working components. All cables to peripherals have been swapped too.)
I have also tried various DVD-ROM and CD-ROM/RW drives in there at times to try booting from any of these as I've run out of things to try. I'm not planning on using an HDD eventually. I've used SD to IDE adapters with success on other projects so will be fitting one, but removed to attempt to solve issues.
The issue seems to lie with the motherboard as I have swapped everything else including the PSU trying higher rated PSUs as well. I've also swapped the CMOS battery for a fresh one. All changes have made very little effect. I've tried OEM boot disks and fresh ones written from allbootdisks.com for Windows 98SE. These disks work fine to boot other PCs and have been used in previous projects.
When I turn on the PC I get the graphics card BIOS and then the CPU detection. AMIBIOS then appears and everything appears fine. I'm able to set everything up correctly. When attempting to boot from floppy I get the message "Searching For Boot Record From Floppy..OK" and the drive spins up for a couple of seconds before stopping and a flashing cursor appearing on screen as if it is about to boot, but it hangs on this screen. Nothing I have tried has changed this. Floppy is first in boot order and drive works properly on other PCs. The drive is able to detect if the disk is just a random disk and is not a boot disk and the board promts for the correct disk. I've reconfigured the BIOS several times after clearing CMOS with no change to the issue. All parts I've swapped out make no diference and booting from CD does not work either. No beep codes and diagnostic LEDs on board all indicate everything is fine and the PC is attempting to boot.
One thing I have noticed is in the hardware monitor section of AMIBIOS the 2.5v sits at 2.6v and 3.3v sits at 3.5v. This is the same no matter what PSU I try. I'm wondering if some capacitors on the board may be on their way out and are causing issues with voltage regulation? If anyone has any ideas what may be wrong please let me know. Also let me know if I should just try to get yet another motherboard and abandon this one. I don't have any others to try and I've poured a lot of time into trying to get this project working so would appreciate any advice.
