Startech PS2 Header from ebay pinout
First post, by candle_86
I finally put a multimeter to the star tech PS2 header, the one with the 5x2 block on ebay popping up everywhere, i tested continuity and matched the wire colors to the pins, i hope it helps someone
Disreguard, upon further research including my own, this no longer matters
Reply 1 of 21, by Horun
Thanks ! and it figures.... bought two a month or so ago and now cannot find them 🙁
Reply 2 of 21, by aha2940
candle_86 wrote on 2020-05-17, 15:16:
Thanks, very useful information
Horun wrote on 2020-05-17, 15:39:
Don't worry, you will find them just the minute the mail arrives with the two new replacements you buy for them 😁
Edit: fixed some silliness.
Reply 3 of 21, by candle_86
Oh the pinout is for the PS2 port itself, and colors provided so you can rewire the header to fit your need, dont use the pinout as what matches the header block
Reply 4 of 21, by aha2940
candle_86 wrote on 2020-05-17, 16:28:
You are correct, thanks for pointing it out. Don't know what I was thinking, fixed my previous post.
Reply 5 of 21, by candle_86
aha2940 wrote on 2020-05-17, 16:45:
No problem I don't want anyone killing a board, but this should help anyone to rewire one. I did this for my Asus txp4
Reply 6 of 21, by Horun
candle_86 wrote on 2020-05-17, 17:39:
I bought them for a P55TP4 and a P6NP5. Must be Asus season 😁.
Reply 7 of 21, by candle_86
Horun wrote on 2020-05-17, 18:37:
this is my TXP4 pinout if it helps you, dunno if ASUS used the same one across all their AT boards,
32.08 KiB
5V is pin 9 fyi
Reply 8 of 21, by Horun
The P6NP5 has it's pinout in the manual and following your color scheme is like this, think the P55TP4 is exact same
edit: yes P55TP4N and P55TP4X are exact same as P6NP5. Am going to use my VM to make sure the Vcc and GND is where the manual states, those would be the killer pins ;p
    9.32 KiB
Reply 9 of 21, by auron
there's a major misunderstanding here, the colors on these startech headers are completely arbitrary and it's always mandatory to check each invidiual one. on mine it's red GND, brown data, yellow VCC and green clock, but many other variations have been posted here: PS/2 Bracket for Asus Motherboard Header
what i've done with mine is to remove the black plastic piece and just put same color jumper wires on the pins, isolating the connections with electrical tape, so that i can use the same header on different mainboards without hassle. the little plastic tabs holding the pins in place tend to break quickly anyway after rewiring 2-3 times.
Reply 10 of 21, by candle_86
auron wrote on 2020-05-18, 04:17:
well damn, sometimes i hate these companies
Reply 12 of 21, by Joseph_Joestar
Artex wrote on 2021-02-07, 04:39:
Since this question has come up a lot, I finally made a video here: https://youtu.be/rFQx8EMc3Mw
Just wanted to say thanks for this. I'm currently trying to rewire a PS2 header to fit a PC Chips M571 motherboard, and your video was very helpful.
My problem is that the connector that the PS2 bracket came with has six sockets in a single row, while the motherboard has 2 rows of 4 pins. I'm guessing I'll need to source a 2 row connector from somewhere.
Reply 13 of 21, by Artex
Joseph_Joestar wrote on 2021-05-26, 11:22:
Awesome! Happy to help! Yes, you'd need at least a two-row connector if there are two rows of pins on your MB header. Some headers have a single row but I'm not sure about your board specifically.
Reply 14 of 21, by PARKE
A set of Dupont connectors is for me almost a must in this hobby:
shorturl.at/erwG0
Reply 15 of 21, by Joseph_Joestar
Artex wrote on 2021-05-26, 13:19:
The pinout for the PS2 headers on the M571 is available here.
A somewhat unorthodox idea came to me, but I'm not sure if it's feasible so I'd like to run it by you guys. What if I get some male to female jumper cables (i.e. such as these) and simply use them to hook up the connector to the corresponding pins on the motherboard (male end goes into the connector, female end to the motherboard pins). Would that work?
Reply 16 of 21, by BitWrangler
Or if you've got any old long tailed wire wrap sockets around you could slip insulation sleeve over the pins, cut them up for 2x3 or 1x6, to plug into board, then bend and trim pins into shape to plug into cable. Or rig it on perfboard.
I did see a surplus store having a crap ton of NOS startech stuff a couple of months ago but can't remember which or where.
Reply 18 of 21, by auron
Joseph_Joestar wrote on 2021-05-26, 14:26:
well yeah, if you read my older post here, that's exactly the method i've described.
Reply 19 of 21, by darry
fgenesis wrote on 2021-05-26, 15:17:
I've looked for these for a long time but they seem unavailable all the time. So if anything turns up, please post.
I don't know where you are located, but for me, in Canada, going to the usual "auction site that shall not be named" and searching for "ps2 bracket" does give multiple results .
Granted, they are not cheap (25ish CAN$ with shipping), not necessarily Startech branded and will require determining the pinout before rewiring as needed .
Another option is making an adapter yourself using a 6-pin female mini-DIN connector .
