First post, by RiP
Does anyone have a user's manual for this board? 🤔
    1.99 MiB
Reply 1 of 6, by therevisiona
RiP wrote on 2020-05-17, 16:10:
Do you know the brand? If you do try searching on this website: Mainboard.cz
Reply 2 of 6, by evasive
There is a FTN-88 manual on file
http://www.minuszerodegrees.net/manuals/Fount … rs%20Manual.pdf
The manufacturer mentioned in the manual is "Fountain" of Thailand. Not much else that I can find right now.
Reply 4 of 6, by evasive
I suppose you have added some memory chips in there for testing etc. Are you sure all of them are in working order? Everything else in the system is tested known good?
Reply 6 of 6, by Deksor
Three beeps with an ami bios is likely to be a ram problem. Try to reseat the chips.
