First post, by TheJoker187
Hello everyone, i'm facing something really strange (for me) with this laptop i found at home. The computer is an old toshiba t1910 with DOS 6.22 installed on it the computer have onboard a segate hdd with 200 mb in size. I have replaced the hard drive with a modern compact flash card and installed dos 6.22 again but, once the machine has rebooted with the new installation of dos the serial port is not recognised anymore msd will not detect the port ! If I put the old hdd inside instead, everything works normally. Another strange thing is that if i try to connect the old hdd to a ide to usb converter to dump the data, the drive will not be detected by the pc (tested on Win10, XP, and 95) i do not know if this is normal the only difference i see in the boot sequence is that when the original hdd is installed on the screen appears: Loading bootloader ... and then the standard dos boot message. If someone knows about it i will be very happy to learn more on those machines and most important to restore this laptop that belong to my family.
Thanks so much to everyone that will help me with that
Reply 1 of 7, by jakethompson1
When it successfully detects the serial port, does it say what IRQ and I/O port?
This is just speculation but I wonder if part of the configuration that normally goes in the BIOS is actually on the HD, or alternatively, if whatever is on the old HD is filling in some info in RAM that DOS uses to figure out where the serial ports are. If interested, there are ways to dig into this with the DEBUG command if I or someone looks up the addresses (BIOS data area, etc.)
Reply 2 of 7, by TheJoker187
Well, when it is recognised it is seen as com1 with the standars IRQ for COM1, there is somethng i can do to give you more information ?
Reply 3 of 7, by jakethompson1
I mean the i/o port in addition to IRQ.
Try this, both with the original hdd and the replacement one.
Run the DOS debug command
at the - prompt type: d 40:00
The first two bytes dumped should be F8 03.
To get out of the - prompt just type q
It will be interesting if the result differs depending on which hard drive you use.
Reply 4 of 7, by TheJoker187
Ok, i've done it if i follow the procedure you suggested, with the original segate hdd i have F8 03 when executing the debug BUT with the other hdd with a clean dos 6.22 installation if i execute the same debug commands i got 00 00 instead of F8 03 ... so something is happening in this segate ...
Reply 5 of 7, by jakethompson1
Yes, weird. I wonder if the BIOS settings are stored in the boot sector rather than in CMOS or something. DEBUG also has an e command you can use to overwrite things in memory. You could try to use that to write an F8 at 40:00 and an 03 at 40:01 and then exit and run msd. Even if this works, it's only until rebooting.
Reply 6 of 7, by TheJoker187
By doing that, IT WORKS, msd see the com1 port correctly, i issued those commands : -e 40:00 F8 ; -e 40:01 03 and after that the port is recognised correctly, so maybe can we create a little bat file that do it at boot ? Maybe i can insert it in the AUTOEXEC file ? Another thing is that if i connect the original segate hdd to a pc it is not recognised so it is possible that there is a partition in the hdd that is used to store bios configuration or something toshiba proprietary, cause i'm unable to dump the original hdd
Reply 7 of 7, by jakethompson1
Debug will read from stdin if you want to do it that way. I'm surprised no one has chimed in about this though, you'd think if all Toshibas of this model worked this way it would be widely known.
