First post, by ZellSF
1) Install Prince of Persia 3D
2) Install Prince of Persia 3D 1.1 patch
3) Launch the game with pop3d.exe -l "geometry\rooms\ivorytwr"
4) Start a new game
5) Walk until you get to the pool and jump into it
With dgVoodoo you get this:
https://www.youtube.com/watch?v=Ets_T38I_hA
You can briefly see here what it's supposed to look like here:
https://www.youtube.com/watch?v=J1i98VY_0CQ&t=3m4s
Also resolution forcing crashes the game if QT4 is installed, some sort of conflict because the game and QT uses the same DLL in a weird way? If you copy the QT file (syswow64\QuickTime.qts) to the game directory and hack it to point to for example ddra2.dll (and make that a copy of dgVoodoo's ddraw.dll) then it won't crash.
