Format floppy disks
First post, by Perro
Hi.
I'm looking for a program to format floppy disks in ms-dos, that is powerful or some trick to recover disks with damaged track 0. Thank you.
Reply 1 of 10, by thierry
Try to look the program NFORMAT , its a nice DOS Format .
The track 0 its a pain in the as.. , try Bulk Eraser First , part of Copy II PC , and second try this one
https://www.youtube.com/watch?v=RaQ6K5Yt1SA
I recover some disk using this tool from the video http://www.classiccmp.org/dunfield/img/index.htm
Reply 2 of 10, by Jo22
thierry wrote on 2020-07-20, 04:40:
I second this.
My workaround was to use WinImage and rewrite a blank disk image/DOS 6 Installation disk image to the damaged disk.
This overwrote the full disk and made it usable again.
Anyway, it's just a temporary solution.
Alternatively, I also used PC-Tools 7 (by Central Point) which has a recovery tool.
It was not always able to safe the disk, though.
Rather, it caused data corruption..
Reply 3 of 10, by Errius
Can you just use a powerful magnet to wipe the disk?
"AI Requires Proof That You Are Human"
Reply 4 of 10, by appiah4
Linux mkfs.fat can do this no problem in my experience..
Reply 5 of 10, by thierry
Jo22 wrote on 2020-07-20, 20:47:
I second this. My workaround was to use WinImage and rewrite a blank disk image/DOS 6 Installation disk image to the damaged dis […]
I second this.
Another one that I use that also saved a 720k floppy disk was Norton Disk Doctor version 4.5, the tool Revive a defective floppy disk, I was able to recover several from an XT Nec V20 PC, although previously I had to clean the floppy disk or with alcohol and swab or some wipes called Huggies that are for children, that one has very good results, but then you have to dry it.
Errius wrote on 2020-07-21, 10:36:
I know someone who tried it but the results were not so good, he told me that he could not format it again.
Reply 6 of 10, by maxtherabbit
If track 0 is physically fucked then disk is trash, no software will fix that
Reply 7 of 10, by thierry
maxtherabbit wrote on 2020-07-21, 13:59:
I do not agree, as I said, I was able to recover floppy disks, first cleaning them, second trying several programs, from 6 floppy disks of 10 recovered being saved.
Reply 8 of 10, by maxtherabbit
Then it wasn't physically damaged
Reply 9 of 10, by Disruptor
1) format it with VGACopy
2) format it in a LS-120 drive
Reply 10 of 10, by appiah4
Disruptor wrote on 2020-07-21, 23:36:
Whoa, I googled this and I am mindblown. I used several versions of X-Copy on Amiga, but never knew such a thing existed for the PC.
