recap question
First post, by debs3759
When replacing electrolytic capacitors, do they need to be the same voltage rating? Can I use 50V caps in place of 35V caps?
Also, which is better, Panasonic FR or Rubycon XYF? Replacing caps on a Hercules GB101 when I know what is OK.
Reply 1 of 2, by therevisiona
debs3759 wrote on 2020-05-20, 10:17:
I would use Rubycon XYF caps, worked for me. As long as the voltage is bigger than the original cap, you are good.
Reply 2 of 2, by debs3759
therevisiona wrote on 2020-05-20, 10:25:
Great, thanks. I have both, but have more of the Rubycon in this capacity. Hope my solder sucker arrives today, so I can get on with the job (not that I have a monochrome monitor to test it on yet)
