First post, by xXmobiusXx1
- Newbie
Hey all, this is my first post to the site.
I can use some help with my Audigy 2 ZS, I recently got this card new open box off ebay and am facing an issue. The right sound channel is a bit weak, it seems as though the low end is not coming through as strongly as the left channel. I have been scouring the internet to find possible fixes and have found that people where replacing the Op-Amps and capacitors with either higher quality or more powerful.
Since I cannot find much information as to what capacitors need to be replaced and what has been proven to work the best I am reaching out in hopes that those who have performed this task can show me what to do and which to use.
I greatly appreciate it
Thanks.
Update: I have found this on digi-key, not sure if this is a good option to try since there is not much info out there on this topic. https://www.digikey.com/product-detail/en/nic … 46-1-ND/7365019
