First post, by MetroidHatchling
I'm currently trying to build a Pentium-MMX PC on a Biostar Microtech MB-8500TTD motherboard using parts taken from a couple other incomplete 286-486 era computers I've had in storage. I intend to put DOS 6.22 on it but I haven't gotten to that point yet. Upon powering it on I get the error "Floppy disk(s) fail (40)". If I continue I get the error "Disk Boot Failure, Insert system disk and press enter". I put a dos 6.22 setup disk into the 3.5" drive and still get the same error, I tried a few windows boot disks I have just to see and nothing different happened. From what I can tell it looks like it might not be reading the hard drive. Perhaps the hard drive is no longer functional? I don't have any other easily accessible IDE hard drives on hand at the moment but I could order one if that's a likely issue. I'm not sure if there are problems with the floppy drives themselves either, though it seems unlikely that everything is broken. I've replaced the CMOS battery on the motherboard and within the bios set hard drive to auto detect. I've tried changing the boot order so that the hard drive boots first to see if there would be anything different as well but nothing has had any effect.
Not quite sure how I should proceed from this point. I can order some new parts if I need to but I wanted to check here first to see if anyone might have a better idea of what's going on before I go buying anything.
Thanks for any help.
