First post, by Living
i dont have the original power adapter but i have some 16v 7.5a power adapters from hp AIOs
what is the pin out of the connector and the power adapter? (+, ground), it doesnst seem to work with connecting in the way it says.
Reply 1 of 2, by DankEngihn
it appears in your picture that the two leftmost pins are Positive (+) and the two rightmost pins are Negative (-).
Reply 2 of 2, by aha2940
Looking on Google, the images found for the adapter of your laptop have the same information: 2 pins are +16V, the other two are ground:
http://www.norsystems.net/cgi-bin/p?showItemD … itemno=ibmG40AC
https://cdn10.bigcommerce.com/s-uak4ckbdhl/pr … 80.1280.jpg?c=2
Are you sure your laptop has no problems?
