Fuse question
First post, by Errius
Hi all. What fuse is this? It has T2H250V written on it. I believe this is slow blow 2A? It came out of an old TV. Where can I see an explanation of the color codes?
"AI Requires Proof That You Are Human"
Reply 1 of 3, by Horun
Appears to be a 2amp normal glass fuse. Check bottom of this page for "four band" fuse: https://slimlab.net/mirror/fusecolours/fusecolours.htm
Reply 2 of 3, by Errius
Thank you, that explains it. T2H = Slow blow 2A ceramic package
Wide blue band = Normal speed
Red-black-red bands= 2A
Not sure why they disagree on speed though. Slow blow should be a wide green band.
Reply 3 of 3, by evasive
The band may have discoloured over time and slow/normal/fast are relative definitions. Slow/fast compared to?
