First post, by itsgallus
Hi there,
How can I get Grand Theft Auto working in 3dfx mode under dos? Can't remember that it was that of a hassle back in the day. I'm using the FastVoodoo2 V4.6 now but the same card as back in the day.
I tried already with coping the GLIDE2X.OVL in the gtados file etc. but I sometimes just get a black screen or a "What 3dfx card?" Error message.
I run it in Windows 98 with a Voodoo 2 Graphics card Diamond Monster II 8mb. Back in the day I could run it without a problem?!
Reply 1 of 8, by auron
try booting to DOS with nothing loaded, and run it there. there's also possible issues with fast CPUs here, iirc.
Reply 2 of 8, by itsgallus
auron wrote on 2020-05-31, 21:57:
well i booted it in DOS itself only nothing happened. but I've read that too with to fast cpu. I once had a p2 300mhz which ran back then in 3dfx mode! what's the limit? should I underclock my p3 600mhz?
Reply 3 of 8, by auron
yeah, try 66mhz bus speed. if that doesn't do it you'd have to get another cpu though as the multiplier is locked.
Reply 4 of 8, by Srandista
A friend of mine couldn't get this game to work on his Voodoo 2, he had to run it with Voodoo 1.
Skip to 7:50 to discussion about that: https://www.dosgameclub.com/grand-theft-auto/
Reply 5 of 8, by zyga64
auron wrote on 2020-05-31, 22:59:
Pentium II 300 is already 66MHz FSB CPU, but there is a good chance that multiplier is unlocked. (chance is even bigger for older Klamath processors).
You probably can go down to 2.5x or even 2x multiplier with L2 cache disabled.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 6 of 8, by derSammler
The P II 300 is what he had back then. He's running a P3 600 MHz.
Reply 7 of 8, by zyga64
I should read more carefully. Shame on me 🤦
Reply 8 of 8, by itsgallus
Well I can run it now as I underclocked my CPU P3 from 600mhz FSB100 down to 400mz with 66FSB. I'm using a very old glide version 2.5 otherwise the Game won't run. This took my ages now I should actually play the Game 😀
thx for the help !
