First post, by aha2940
Hi guys
I have an old IBM thinkpad 360Ce laptop (486DX2-50, 20MB RAM, 500MB HDD) which uses two little batteries:
- A Panasonic lithium VL2020 battery, which AFAIK is used for CMOS and clock
- An IBM NiCd 3.6V battery P/N 66G0119, which seems to be used when the laptop is suspended
However, these batteries are long dead (the laptop is 25 years old). My questions are:
- Are these batteries rechargeable, or are they simple batteries? I've found some mixed answers on the web.
- Depending on answer 1, what can I use to replace them? I could buy the same exact ones, however I think paying 15+USD plus shipping plus importation fees for a single battery is too expensive, I'd rather get something locally. I have some space internally on the laptop, since I replaced the HDD with a CF card, I could fit a bigger battery if needed, and run some larger cables.
Thanks for any pointers.
    186.39 KiB
    IBM 66G0119 battery
    381.73 KiB
    Panasonic VL2020 battery
Reply 1 of 12, by Doornkaat
Both are rechargeable.
First is three NiCd cells (1.2V each) in series (resulting in 3.6V), usually any NiCd pack with three cells in series is a suitable replacement. Second is a VL2020 (Vanadium-Lithium coin cell) with wires attached which you probably already knew. 😉 You can buy the cell with solder tabs, solder on the original leads and wrap it in electrical tape for isolation.
Reply 2 of 12, by aha2940
Doornkaat wrote on 2020-06-02, 04:59:
Thanks for the information, very useful. Regarding the VL2020, I've read that soldering (heating, in general) a battery is dangerous because it can explode, is it true? or it can be done without much problem? any special care about it?
Reply 3 of 12, by wiretap
Just keep the iron on it for only a few seconds. If you have it on there for an extended period of time to try to melt the solder, your temperature is set too low and all you're doing is pumping heat into the battery
My Github
Circuit Board Repair Manuals
Reply 4 of 12, by Doornkaat
aha2940 wrote on 2020-06-02, 13:46:
What wiretap said plus I think the VL2020 always comes with solder tabs. They don#t transfer heat too quickly so if you pre-tin their ends and the wire's ends you only need to heat them very shortly to attach the wires. If you have a little bit of soldering experience this is a job you can 100% do! 😀
Reply 5 of 12, by aha2940
Hi again guys
Thanks a lot for the advice on soldering, really useful stuff. So, I've been doing some research and VL batteries are just expensive. So I looked for other options to get the 3.0V of the VL2020 and the 3.6V of the IBM battery and found several options:
3V:
bateria-cilindrica-varta-cr-12-aa-lithium-3-v-950-mah-D_NP_878801-MCO31121325649_062019-X.webp
3.6V:
bateria-verde-36v-60mah-pila-maquina-multijuego-D_NP_770541-MCO27424270921_052018-X.webp
pila-bateria-recargable-telefono-inalambrico-t-107-beston-D_NQ_NP_716819-MCO42001452481_052020-O.webp
However some of these have a huge difference in mAh capacity when compared to the original batteries. Would that be a problem? should I stick to batteries having the same mAh capacity? or it does not matter?
Thanks!
Reply 6 of 12, by chrismeyer6
Just make sure they have the same or higher capacity not less. And for some of the bigger capacity batteries they tend to be larger as long as you have the space for them you can go for the higher capacity ones.
Reply 7 of 12, by Doornkaat
As far as I know batteries differ greatly depending on their chemical composition and will react badly to wrong loading currents. This may range from not accepting any charge at all over early failure to leaking or exploding.
Depending on the loading circuitry it may be fine but it may also overheat with high capacities or interpret wrong capacities as defective cells and outright refuse loading them.
The loading circuitry on that laptop is probably specific to a certain type of cell so it should be replaced with that type or it may cause damage.
What you want to look for for the VL2020 is a Lithium Vanadium Pentoxide (LiV2O5) cell. Doing a quick search I can find suitable batteries for ~5€. I don't know about the Colombian supply though.
The other one is a nickel–cadmium battery. The Beston pack you posted consists of Ni-MH cells that are much more sensitive to overcharging. They use similar loading voltages so you can probably get one and see how hot it gets.
I know of people who replaced them with supercapacitors but again I'm not an expert and I don't know what issues may arise from this solution.
Sorry I can't give you a more conclusive answer.
Reply 8 of 12, by appiah4
Lithium batteries are not rechargable so don't use that.
The barrel battery will leak onto the board so don't use that.
I have used that cordless phone pack with AT motherboards with great success in the past, go for it. Use dupont jumper wires to relocate it toa part of the case where it won't harm anything if/when ti leaks. NiMH is less prone to leaking anyway, and recharge characteristics are the same as NiCd.
Reply 9 of 12, by aha2940
Thanks for your insights guys, it seems choosing a replacement battery is not as simple as it seemed at first. I got confused by this though:
appiah4 wrote on 2020-06-05, 13:13:
However the listing for the Varta 3V battery says it is rechargeable, and the original VL2020 battery on the laptop is lithium (see pic in first post) and also rechargeable, so I do not understand, are some lithiums rechargeable and others not?
Reply 10 of 12, by derSammler
Both VL and CR coin cells are Lithium batteries, with the VL series being rechargeable. And every modern device also uses rechargeable Lithium batteries. It's not the Lithium that decides whether a battery is rechargeable or not, but the material used in conjunction with it.
Reply 11 of 12, by appiah4
The pictured Lithium battery is a CR 1/2AA, it's not a rechargeable Lithium battery.
Reply 12 of 12, by Mister Xiado
I've got a 760E with a shattered screen that needs the same batteries to even boot. Thanks, IBM. I especially appreciate the sloppy soldering I found when disassembling the keyboard to get to them. Alas, I've never been able to locate a replacement for the triple cell pack myself at any price, and while $10 for the singular cell is a pain, without both, my busted laptop remains eternally inert.
