First post, by vvbee
Extracts data from Grand Prix Legends's DAT files. Converts textures into PNG and 3D models into OBJ/MTL. Also works with track meshes (recursively converts all 3DO dependencies except for the horizon) but not with cars.
The DAT extractor and texture converter are written in PHP7 and will run on the command-line with a PHP7 interpreter. The mesh converter is C++ and requires a compiler that supports the C++17 filesystem library (e.g. GCC 9).
The 3D models that ship with the game have been pre-compiled into a tree structure with polygons at the leaf nodes and rendering metadata along the branches. The model converter comes with a tree traversal implementation that you can in theory subclass to extract specific data - by default the converter extracts the 100% LOD mesh with its polygons and materials.
https://github.com/leikareipa/gpl-dta
    592.67 KiB
    Exported Spa track mesh loaded in Blender
