ASUS P/E-P55T2P4D - dual socket 7 motherboard
First post, by cyclone3d
Since I have had requests to post about this board, I will start with some pics and what was still available from ASUS for starters.. and then once I have time to actually play with this board I will post some more about it.
ASUS' page:
https://www.asus.com/supportonly/PE-P55T2P4D/
Files from ASUS:
Manual:
The attachment p55t2p4d-200.pdf is no longer available
EISA cfg:
The attachment t2decu.zip is no longer available
BIOS:
The attachment td5e0106.zip is no longer available
The attachment td5e0107.zip is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 24, by cyclone3d
Pics:
The attachment P_E-P55T2P4D.jpg is no longer available
The attachment jumpers_1.jpg is no longer available
The attachment jumpers_2.jpg is no longer available
The attachment jumpers_3.jpg is no longer available
The attachment jumpers_4.jpg is no longer available
YMF7x4 Guide
Reply 3 of 24, by luckybob
Oh yea baby. Thats what daddy likes.
Reply 4 of 24, by Nezarn
If it works, can you post some benchmarks with 1 vs 2 cpu? 😁
Reply 5 of 24, by Doornkaat
PCI, ASUS Media Bus, ISA and EISA?
Watch out, you so called "VIP" boards! 😁
Reply 6 of 24, by red-ray
Which OS do you plan to install? I wonder if it will run 2003 Server will run and if both CPUs will show up.
Once you have an OS installed I would like to know what my SIV utility reports for it, especially if any EISA cards are reported on Menu->System->ISA Bus.
Reply 7 of 24, by cyclone3d
Ok, so I am finally getting to mess with this board a bit. I was waiting for a 512KB COAST module to arrive and it finally did and actually works. I wasn't 100% sure it would work as the manual has a very sketchy support list.. as-in they only ever validated the ASUS CM1 Rev 1.6 w/tag.
The board boots up and works fine with Intel chips but even when setting the proper voltage for an AMD chip, the one VRM just gets burning hot and the board doesn't POST. Only have the multiplier set at 1.5/3.5 so that shouldn't be it. Maybe I have multiple dead K6-2 chips. Guess I need to test with a SS7 board to make sure the K6-2 chips are working.
I have an upgrade CPU around here somewhere just not sure where I put it... Interposer with a K6-2 333 installed so I will try that as well.
YMF7x4 Guide
Reply 8 of 24, by chrismeyer6
That is a really nice looking board and it sounds like a fun project to work on. Which OS are you considering for dual CPUs?
Reply 9 of 24, by cyclone3d
chrismeyer6 wrote on 2020-06-27, 20:57:
Probably Windows NT or 2000 depending on if I can get AMD K6-2 CPUs working or not.
YMF7x4 Guide
Reply 10 of 24, by chrismeyer6
Nice! Maybe dual boot of Windows NT4 and 2K
Reply 11 of 24, by chinny22
I was under the impression K6 didn't support SMP?
Or was I just a victim of Intel's stronger marketing
Reply 12 of 24, by H3nrik V!
chinny22 wrote on 2020-06-29, 10:27:
That's what I thought too ..
But to my knowledge, Intel was all alone (maybe except from ServerWorks) to manufacture SMP enabled chipsets, thus making it easy to omit support for AMD parts ..
Reply 14 of 24, by Anonymous Coward
I think this was discussed here in a thread a few months back. I can't remember the exact terminology used, but it turns out that K6 chips do support some form of multiprocessing, but it's not compatible with the standard used by intel CPUs, and no products that support it exist.
Reply 15 of 24, by luckybob
Updates? Its been over a month and my stones are blue with anticipation.
Reply 16 of 24, by cyclone3d
luckybob wrote on 2020-07-08, 22:14:
Still sitting there waiting for me to mess with it again.
Probably won't get to play with it until after next week.
YMF7x4 Guide
Reply 17 of 24, by luckybob
cyclone3d wrote on 2020-07-08, 23:17:
...Probably won't get to play with it until after next week.
Has it been a week? ^.^
Not being a dick, but I just can't get enough of that big beautiful bastard.
Reply 18 of 24, by TimWolf
Following
Reply 19 of 24, by cyclone3d
Ok.. so an update as I plan to actualyl put together a system with this board very soon.
I was able to find the second highest Mediabus card released which I though I would never find... the PCI-AV264GT. It only differes form the highest model (PCI-AV264GT/Plus) in that it only has 2MB RAM compared to the Plus which can be upgraded to 4MB and has SGRAM.
Apparently Wikipedia is incorrect as it says this card is supposed to have the ATI Rage but the one I have on the way has the 3D Rage II which is the same as the Plus model.... maybe there were 3 models????
Seller's pic:
The attachment PCI-AV264GT.jpg is no longer available
I was also able to locate my other CPU adapter so I can verify whether or not 2x AMD K6-2 series chips will work or not.
If that doesn't work, I will try with a single Tillamook 266Mhz and if that work with the on-die cache, I'll go ahead and order a second one.
Otherwise I will be stuck with dual 233MMX CPUs.
Oh yeah.. I also have a nice EISA SCSI adapter to try out on this thing as well. Probably going to end up going with a PCI SATA controller and SSD in the end but since I have EISA slots I wanted to try out something that uses them. I probably have an EISA video card as well.. not 100% sure on that though as it has been a while since I bought EISA parts.
YMF7x4 Guide
