First post, by Janeshi
Hi everyone!
I have an ECS P5GM-LG in working condition, BUT, I was trying to fit this MOBO in any case an was (almost) imposible.
Does anybody know where could this mother came?
I found all the information about this mother but nothing regarding in which/for pre-build machine was built in.
http://powerspec.com/support/system_boards/p5gm_lg.html
Reply 1 of 4, by dionb
Not familiar with the board, but that's LPX form factor with PISA riser slot.
The board itself should fit in any LPX case, but the risers are notoriously non-standardized, so getting one that will both fit this board and whatever case you find could be the biggest challenge.
Reply 3 of 4, by dionb
evasive wrote on 2020-06-04, 07:54:
Looks like it came from a Packard Bell - Legend 266 or at least it will fit that case:
https://www.clubedohardware.com.br/forums/top … ell-legend-266/
You sure about that? The only MediaGX board I'm aware of PB using was the 860, which is LPX with PISA, but the similarities end there - most importantly a completely different external connector layout.
Reply 4 of 4, by evasive
dionb wrote on 2020-06-04, 08:32:
No I am not sure, hence the wording. I see I forgot to put in "possibly".
