First post, by tomexplodes
Hokay, lemme figure out my specs.
It's a Compaq Presario 7000 series, number is 7AP140, it's had some modifications from stock.
I've got an ATI Radeon 7000 series 64mb card installed, driver version 6.2 I believe? Latest I could find for 98.
I have an AMD Athlon of some kind with 800mhz.
512 MBs of RAM
Sound Blaster PCI 128 is my sound.
I also installed the unofficial 98SE SP3, mostly just the core stuff and DirectX 9.0c I believe. I did this after D2 already didn't work, though.
ANYWAY, here's my problem(s)
I install Diablo 2 from the discs, put in key, yadda yadda. Install goes fine. Recommends Direct3D, so I say sure why not. Reboot. Game won't run. Try to install patch, this happens:
"Blizzard PrePatch v2.70 compiled on Sep 9 2003
This program patches Diablo II
Log created at 5:52 pm on 06/05/2020
Registry error saving key 'Patch\Patches'
The configuration registry database is corrupt.
RESULT: Prepatch failed"
That's on every patch version I've tried, including after installing LOD and trying LOD patches. Every patch the same.
When I try to boot D2 vanilla, no patches, nothing, it doesn't load. Just nothing. When I try to boot LOD without any patches, I get the opening cinematics, it gets to the D2 loading screen, and then it hangs. Ctrl+Alt+Del does nothing. Hard power off necessary to get back to things.
SO I hope this is enough information, can anyone tell me why in the world D2/LOD won't run on my more than capable Windows 98 machine? I would really appreciate it. Thanks!
PS I tried installing the download version on my modern(ish) PC and copying the files over, same junk, no go.
EDIT: Should note I added my DxDiag just for fun, also that I originally installed it in D:\Diablo II, then I tried again in C:\Program Files\Diablo II, same result.
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows XP, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
Reply 1 of 7, by kolderman
Which patch? Did u install expansion first?
Reply 2 of 7, by tomexplodes
kolderman wrote on 2020-06-05, 22:59:
Tried 1.12b, 1.13d and 1.14d.
No, why would I do something stupid like that?
Reply 4 of 7, by tomexplodes
Okay maybe I misunderstood. I tried installing LOD patches AFTER installing LOD. I then tried just vanilla D2 with VANILLA D2 patches and they also didn't work.
Reply 5 of 7, by kolderman
tomexplodes wrote on 2020-06-05, 23:23:
Was it the same error each time? Have you run a registry fix tool?
Reply 6 of 7, by tomexplodes
tomexplodes wrote on 2020-06-05, 22:36:
"Blizzard PrePatch v2.70 compiled on Sep 9 2003 This program patches Diablo II […]
And yes.
Reply 7 of 7, by tomexplodes
Did a fresh Windows install and now Diablo 2 works just fine. Beats me.
