First post, by nwsw
Hi All,
I've been reading up and building this thing for the last few weeks, it's finally complete. I haven't built one of these before, but I've been building PCs since 2000. Thanks to darry for helping me troubleshoot video card issues.
Specs:
Abit BX-20 Slot 1
Pentium II 300 Mhz
128 MB RAM
4 GB CF Flash IDE HDD
IDE CD-ROM
GOTEK Floppy Emulator
Windows 98SE
Nvidia MX 4000 64 MB AGP 4x
Soundblaster Vibra 16 ISA
Fractal Design ATX Case
Roland SC-55 w/ HardMPU (Do I need HardMPU with SC-55?)
Plays everything great and I'll be getting the rest of my SC-55 this week. I use Phil's Easy DOS mode for picky stuff. Pardon the last fuzzy shot.
The attachment pcbuild.jpeg is no longer available
The attachment pcfront.jpeg is no longer available
The attachment quak2.jpg is no longer available
The attachment simcity.jpg is no longer available
The attachment roland.jpg is no longer available
Reply 1 of 6, by MKT_Gundam
Nice build!
I would suggest changing the CF for sd/ide. Cf cards are slowers and wears fast. CF cards are more suited for DOS .
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 2 of 6, by kolderman
Well it depends what you mean by "need". A big free midi interface is very nice to have. Few soundblasters do. But the intelligent mode is not used by GS/GM games, only MT32 games, so you could do with a different sound card with a bug free mpu, like an awe64 or an ess audiodrive.
Reply 3 of 6, by nwsw
MKT_Gundam wrote on 2020-06-11, 03:44:
Nice build!
Thanks! I ended up swapping for a SD/IDE instead, works very well. Also picked up a new NEC 15" LCD in box for cheap which really makes the old thing shine!
Reply 4 of 6, by chinny22
I think from memory alot of the Vibra's are bug free, although if you have a MPU card doing nothing makes sense to use it.
I like it, its nothing flashy, most of us would look to have some P3 in a BX system even though a P2 will probably play most games just fine.
Reply 5 of 6, by SodaSuccubus
nwsw wrote on 2020-06-15, 06:52:
Nice build!
Can anyone else vouch for the life expectancy of SD-IDE under heavy Win9x use?
I know for sure CF cards are a bad idea, iv gone through multiple quality cards in a week of heavy use thanks to all the writing Win95/98 does. Switched to Sata-IDE and have had no such issues.
Reply 6 of 6, by SpaceCadet
SodaSuccubus wrote on 2020-06-16, 17:13:
Not under Windows 9x, but I have used SD cards in various raspberry pi 1/2/3 projects with higher IO rates than you'd normally see in Windows 9x and they seem to last for years. I only had one SD card die on me, but that one was flaky from the start: it lost its data right after installing on it for the first time. After re-initializing everything, it worked again for a couple of hours, then permanently died.
