First post, by Patrick
Hi,
I have an ES1868F with blown components around a 386D JRC (sorry, I can not inline photograph, my host is HTTP only).
There is two 386D with the same components around, maybe one for left and one for right sound channels.
There is resistors, R25 (blown) and R24, SMT with label "100"? No problem it is 10 Ohms.
There is capacitors, C30 (blown) and C28, SMT no label.
And there is some unknown components, X12 (blown) and X11, SMT. I don't know what X means.
I need help to identify these components .
Thanks
Reply 1 of 5, by kalohimal
X usually means crystals, but that sure doesn't look like an smd crystal to me, and more like a normal capacitor. If you can get hold of a capacitance meter you could measure the one on top and take a look. It's connected to pin 6 of the 386d which is V+ and a big plane which looks like ground, so it's most probably a bypass cap. The failure is most probably a short in "X12" causing the blown up. C30 is also possible but not so likely since it has R25 in series. You might also want to check the via near C30, and also output pin 5 of the 386d to V+ and ground in case the amp is shorted. Check also C29 since electrolytic caps are prone to aging.
1.81 MiB
83.76 KiB
26 KiB
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 4 of 5, by kalohimal
You could but I don't think that is necessary now that we have the schematic. Card manufacturers usually just follow the reference design from the datasheet. Other components on your card match those in the datasheet so it is quite certain that they just copy the reference design.
Reply 5 of 5, by Patrick
I have done the schematic around the 386, following the tracks.
According to the datasheet, X12 is 100nF and C30 is 47nF, so you were right.
Thank you all. I will try to replace blown components with these values.
