First post, by matcarfer
Hey guys, I'm trying to build a really fast (but compatible with official drivers) Socket 754 with Win98SE support.
Here are my current motherboards:
ASUS K8N REV 1.01 NVIDIA nForce3 250
ECS 755-A2 (V1.0) SiS 755 / SiS 964
Gigabyte GA-K8VM800M REV 2.0 VIA K8M80 / VIA 8237R
ASRock K8Upgrade-VM800 VIA K8M800 / VIA 8237R
As far as I saw, all have 9x drivers. Any recomendations? Any experience on those chipset under 9x?
Will put an AMD Athlon 64 3000+ , a GeForce 5600 Ultra and an Audigy 2 ZS.
Reply 1 of 5, by appiah4
Definitely go with VIA. K8T800/K8M800 are rock solid and has much better DOS compatibility with PCI cards.
Reply 2 of 5, by frudi
Both VIA and nVidia have their chipset issues. As already mentioned, VIA has better DOS compatibility for sound cards. On the other hand it doesn't support SATA2 or SATA3 drives (sometimes they work if they have a SATA1 compatibility jumper, but even that isn't necessarily reliable). nForce chipsets also have a tendency to get (too) hot, so you should consider adding some active airflow over the usually puny chipset cooler.
They both can also have their own driver issues. I've had nForce not install properly or cause blue screens, while I've had VIA Hyperion missing drivers for some components or cause conflicts or errors after installation. Honestly I wouldn't call either of them good in terms of driver reliability.
This is all based mostly on dealing with nForce 2/3/4 and KT600/K8T800/K8M800 boards on Windows 9x/ME. I haven't had much experience with SiS chipsets though, so can't really comment on those.
Reply 3 of 5, by kolderman
SiS chipsets are good. Not performance kings but very solid. I like the kt333 chipset.
Reply 4 of 5, by matcarfer
appiah4 wrote on 2020-06-12, 04:27:
Well I'm glad I asked cause I didn't knew that.
frudi wrote on 2020-06-12, 10:15:
Yeah, no chipset is perfect specially in 9x, thats why I asked. I had my share of issues with some older VIA chipsets in the past under 9x and same with nForce 2.
I plan to use an IDE drive so will not have SATA problems. Thanks
kolderman wrote on 2020-06-12, 10:24:
I never liked SiS, always had crap performance AND stability issues, mainly in PCChips motherboard, but I asked cause that could be different this time.
Reply 5 of 5, by appiah4
SiS were premium chipset manufacturers in the 386/486 days. Their K7/K8 chipsets are also fairly robust if not high performance. I believe the hate towards SiS chipsets stems mostly from their rather mediocre Pentium onwards Intel platform chipsets?
