First post, by 386SX
Hi,
I've bought an horizontal case for my 386 mainboard 1992 AT size. The case is really slim with a ISA riser card with connectors on both side and a total of four ISA cards to install. The owner told me it is supported by any mainboards with ISA connectors (do you confirm?) and anyway it unfortunaly lacks the metal frame/chassis for the 3,5" floppy drive or eventually the hard disk usually found near the left of the 5.25" drives slots. Beside using some 3,5" to 5,25" adapter are those things "standard" metal chassis to install on the left side of the 5,25" one a common 3,5" drive in its own slot without using the bigger ones?
Thanks
