First post, by zPacKRat
3+ weeks in and I've swapped out my PA-2013 v2.0 for an Abit BE6-II v2 and it's like 20 years ago all over. I figured that it would be fun to tinker with the FIC board for a while, tune it, get it stable, relive the first PC I built, etc. Well under 98se that has not happened, multiple clean installations, 4in1 drivers, Nvidia drivers and what works for an hour one time freezes the next. I replaced all the capacitors on it, cleaned it up and removed any traces of oxidation/corrosion with IPA and a toothbrush and at the end of the day it's marginally better, but frustrating enough that it's being put away with the consideration of putting it on ebay because I'm not sure I want to relive this experience again, 🤣.
Build consisted of:
1. PA-2013
2. K6-3+ 450
3. multiple sticks of PC100, 133 of different sizes
4. CreativeLabs TNT and TNT2 Pro
5. ISA AWE64
I could swear that this was a stable platform at one time, maybe it wasn't and I'm just trying to create a positive memory, maybe I'm spoiled by how well thing work now. But boy oh boy that Abit board is a gem with a Piii 700 and 384MB or ram along with the AWE64 and TNT2 I'm happy for now, the only thing I want now is a pair of VooDoo II's. I wish I could remember what the difference was when I did this similar upgrade originally (BH-6 and Celly 300A)
Reply 1 of 39, by brian105
In theory the config should work perfectly. Did you try updating/reflashing the BIOS? Maybe using a different GPU? (agp if using pci, pci if using agp)
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 2 of 39, by schmatzler
Ha, seems just like the experience I had when I switched from a FIC PA-2012 to an Abit VH6T.
The Abit board is so much more stable than the FIC one. I recapped both of them and tried various 4in1 drivers on the FIC, it would never run as well as the Abit. Occasional hangs and bluescreens, massive performance issues...I threw it into the trash last week, that board was absolutely unuseable.
Maybe it had a difficult hardware problem I was unable to solve.
Reply 3 of 39, by will1384
I have an old Sound Blaster Live CT4760 with gold connectors, the sound card looks good, I can't see any problems on the board, and I got it pretty cheap and was said to be working, but it just will not work for me, wont work with the DOS drivers, and wont work with any Windows drivers I have tried, I tried 5 different drivers yesterday, I will try it in another computer today, I have some Sound Blaster Live CT4670 and a few other Sound Blaster Live cards with the "EMU10K1-ECF" chip and they seem to work fine with the correct driver, but this Sound Blaster Live CT4760 with gold connectors has a "EMU1OK1-NEF" chip, so I am thinking about getting or making a chip programmer and seeing if the card has a damaged EEPROM and / or reprogramming the EEPROM to something a driver will work with, there seems to be a good "how to" over at:
http://ixbtlabs.com/articles/livetolive51/index.html
If an EEPROM reprogram does not work the Sound Blaster Live CT4760 goes into a parts bin.
I had a lot of trouble with Windows 95 when it first came out, I had so many problems that it took me the better part of a week before it ran "acceptably" and even then it had a lot of BSODs,crashes and lock-ups, Norton used to sell a software called "Norton Crash Guard" just because crashes were so common, and there were a lot other companies out there selling software just like it, "Fix-It" was another, "WINProbe" I think was another, "First Aid" was another, crashes were common, and I remember most of my problems seem to come from "VXD" drivers, Windows 98SE was far more stable on my hardware than Windows 95, but I still had my fair amount of crashes with it, "most" of the problems went away with Windows XP.
Reply 4 of 39, by zPacKRat
will1384 wrote on 2020-06-16, 23:14:
I have an old Sound Blaster Live CT4760 with gold connectors, the sound card looks good, I can't see any problems on the board, […]
I wonder if you could wire an Xbox 360 rom programmer to do this without removing it.
Reply 5 of 39, by Joseph_Joestar
If all else fails, try using Audigy drivers and see if they detect the card: Guide: Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1)
Another user got his CT4830 working using that method, while all the regular Live drivers that he tried had failed.
Reply 6 of 39, by zPacKRat
brian105 wrote on 2020-06-16, 22:46:
Here's a high level recap:
1. re-flashed 4333 and tried 4330 to 4333, no difference except large HDD detection
2. tried the following 4 in 1's 4.25, .35 and .36, even tried what is on the CD that came with the board. 4.35 seemed to work best, however there was a time with no 4 in 1 drivers installed it seemed stable.
3. tried several NVIDIA drivers, 2.08, 3.68, 5.32, 6.26 and 36, 30.82, 44.03. Found 44.03 to work consistently and some, don't remember which would black screen with the blinking cursor.
4 Old Jayton PCI 4MB card worked fine.
What I found is it's really a 3d issue. When it locked, I could launch Quake II and hit enter to get the menu, but when I hit the console key it would lock, or if I let it run out to the demo playback it would lock. Software render was fine. I also found that with the 4 in 1's that if I disabled turbo (AGP x2) or if I didn't use the 4 in 1's and disabled it in the bios it was far more stable. Last thing I did was run it for over an hour with crusher and massive demos looped in QII and it was fine. this was with no sound card, I then installed a sb live value (CT4670) and the drivers from the CD and I wound up with a beeeeeeeeep in when it locked up consistently, in different PCI slots. It's now all put away.
I'm sure there's more, it's been a trip down memory lane for sure.
Reply 7 of 39, by will1384
zPacKRat wrote on 2020-06-17, 00:07:
I am thinking about trying to use a chip programming clip if I can, or maybe removing and replacing the chip and putting some sort of chip and socket combo on the sound card, I will have to look into it more.
Joseph_Joestar wrote on 2020-06-17, 00:12:
Unfortunately I tried the Audigy drivers yesterday and they did not work.
Reply 8 of 39, by Cga.8086
i throw towel when:
1) old 486 motherboard with green barrel battery leaked, eaten traces all over, and eaten bias. I am not going to invest time on trying to repair such a mess, and i just remove bios, remove cache an throw it.
2) when the motherboard just doesn´t power on, and the psu fan does not spin.
Reply 10 of 39, by Intel486dx33
When the pcb or GPU are too damaged to repair.
Reply 11 of 39, by EvieSigma
My "throw in the towel" point is when something just will not work no matter what I try and then I find it on eBay for a low price/less than I paid for the non-working one.
Reply 12 of 39, by candle_86
When in anger I've thrown it against the wall
Reply 13 of 39, by darry
EvieSigma wrote on 2020-06-17, 01:59:
This ^^
Reply 14 of 39, by babtras
I've been working on a 286 laptop for a year. I have thrown in the towel at least a half-dozen times, boxed it up, put it away. Then thought about something I hadn't tried while laying in bed and opened it back up the next day. I can't help but keep going back to it because I love the look of it, the keyboard, the orange display. I would have gutted it and put in a 4GB Raspberry Pi 4 as a "sleeper" if it weren't for that orange monochrome display that I really want to preserve.
Reply 15 of 39, by Caluser2000
If I haven't figured out what's wrong with something within about 6hrs in to the parts box it goes.
Reply 16 of 39, by Tetrium
When building a new rig which turns out to behave improperly, I'll just start the troubleshooting process till the problem gets eliminated. So sometimes I'll end up with other parts than I had originally intended to use but that's fine for me, it just comes with the territory.
Depending on whether the part is suspected to be defective or not, I'll put it in my parts box of parts that may need to be looked at more closely at some later moment (I label many items that I use but will definitely label if I had some issues with it so I don't end up accidentally spening a second batch of hours troubleshooting the same item over again 🤣).
My retro rigs (old topic)
Report spammers here!
Reply 17 of 39, by PTherapist
I tend to throw in the towel when I've pretty much exhausted everything I can do.
For example on an old 8088 motherboard I have, from my first PC, it doesn't POST and had numerous issues that I was able to fix such as a broken BIOS chip & a snapped off tantalum. But then there were more trickier issues, such as a pin stuck inside a SIPP slot in the first slot and also not having any SIPP RAM in my collection, plus a socketed chip with visible scorch marks that seems difficult to source a replacement (hadn't checked aliexpress). Those issues might be fixable, but then I'd be unsure if the board had other further issues so I've given up for now and stored the board away.
Reply 18 of 39, by Windows9566
I gave up on a Macintosh Performa 400 that had a leaky battery, the motherboard was just obliterated by the acid. to the recycling container it goes, I got that mac for free anyway, the damage was too much, It couldn't be fixed since the acid ate many of the traces and the ICs were corroded to hell. Those lithium 3.6V batteries, especially the Maxell branded ones in those old Macs are ticking timebombs. I kept the case since it just had minimal yellowing and a couple scuffs. I'll throw in a LC II or III motherboard into it in the future to revive it. The PSU looked fine though, and even outputted the correct voltages, and the HDD spun up and was recognized when i plugged it into my Mac IIci, it has System 7.1 on it.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 19 of 39, by Miphee
I'm too stubborn to give up on anything. So I start messing around until I fck something else up and realize that it's trash now. Into the hopeless pile it goes! (not the actual trash, my mental block prevents that)
A few months pass and I start tinkering with them again... I love hopeless cases.
