First post, by stopi
Will graphic card Cirrus Logic cl-gd5401-42ac-b work in IBM XT 8-bit motherboard as well as in 386SX motherboard?
I have HLH386SX motherboard (Nic Technology) and try to buy Cirrus Logic graphic card at good price. I hope it will work. I hope it will work in 8-bit ISA slot on TD-20 Turbo XT motherboard (4.77MHza IBM XT based on 8088 CPU).
Reply 1 of 6, by Schule04
Yes, it will most likely work.
The GD5401 is a rebranded Acumos AVGA1 chip from when Cirrus bought Acumos. I use a card with that chip in the 8 bit slot of my 286 and it works well.
There's even a driver for windows 3.x to use a resolution of 800x600 with 16 colors on the card, however it's pretty slow.
Reply 3 of 6, by darry
stopi wrote on 2020-06-20, 21:48:
Is Herkules Proton PT6121T faster and better card? I can buy it too.
That is not a VGA card . It will not work with VGA software . It will require a monitor compatible with Hercules monochrome graphics standard . If memory serves, an MDA compatible monitor will work .
Reply 6 of 6, by Nelson68k
The AVGA1 / CL-GD5401 runs well in a 386. Also in 8bit. I have built one for myself.
962.33 KiB
homemade GD5401 VGA card
