First post, by Juan-san
I'm looking for an ISA sound card to install into my secondary P-III build and happened to find a listing for this OEM card. Notice the slot connector at the bottom left.
The attachment placa-de-sonido-compaq-D_NQ_NP_9.jpg is no longer available
The board I plan to use it with is a Soyo SY-6VBA133 (VIA VT82C693A), which comes with 16-bit ISA PnP slots. Any idea on what those extra pins are for?
Reply 2 of 5, by kalohimal
ESS Audiodrive ES1868F can be easily found on ebay and other places and they are inexpensive. Why not get a "normal" one?
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 3 of 5, by Juan-san
There are no visible traces going from the pins to any of the components in the card, as far as I can tell from the pictures in the listing.
The attachment placa-de-sonido-compaq-D_NQ_NP_752042-MLA30329818698_052019-F.jpg is no longer available
Reply 4 of 5, by mkarcher
Juan-san wrote on 2020-06-20, 06:44:
Compaq computers often allowed the sound card to play back through the internal (PC-)speaker if no headphone or speaker was connected to the card, so these pins are most likely speaker out (only active if nothing is plugged into the sound card. It might also contain PC speaker input to the sound card, so that PC speaker sound is also played through external speakers and controllable by the mixer. If you leave the pins unconnected, the card will most likely work.
Reply 5 of 5, by mkarcher
Juan-san wrote on 2020-06-20, 07:22:
This back side picture is of insufficient quality to tell anything about traces to the pins F1-F3 (extending the ISA naming scheme using A1-A31, B1-B31, C1-C18, D1-D18). The picture you showed in the original post has R40 clearly connected to pin E1, and R28 and R39 to vias (holes in the card to connect traces on different sides), so my guess is they are connected to F1 and F2. The numbering scheme R39/R40 indicates those two pins might be a stereo pair (speaker out), whereas R28 (with no similar-named resistor near to it) is a monaureal signal (PC speaker in?). The resistors inbetween the pins and the remainder of the card are a good indication for analog signals on those pins.
