First post, by shoes23
Sorry if this has already been posted...I've read through the readme file, and browsed about 100 topics on the forum. Can I permanetly mount dosbox to a directory (i.e. mount dosbox to the c: drive so I don't need to type mount c: c:\ everytime the program starts?)
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
yeps
just add the mount commands to the configuration file
just open the file and you will under stand.
Water flows down the stream
Reply 3 of 5, by HunterZ
For anyone else that has this question:
At the end of dosbox.conf is a section called [autoexec] which is a lot like the autoexec.bat file in real DOS. Any commands you put there will be run automatically whe DOSBox starts.
Reply 4 of 5, by absolutefunk
Also it saves time by adding your CDROM mount command there as well as "C:" so that you start at the C: prompt instead of the Z ram drive.
-Brian
Reply 5 of 5, by HunterZ
Yeah, this is what I have in my [autoexec] section:
[autoexec]
# Lines in this section will be run at startup.
mount c d:\oldgames
c:
