First post, by nil
as above, how can i run dosbox in text mode without x11, i don't want to get in Xwindow, is this possible or not?
thanks for your read and reply.
Edited by mirekluza: Removed orange coloring of the text to save eyesight of our visitors...
Reply 1 of 7, by eL_PuSHeR
Hey, do you want us to go blind? change that awful font colour... 😁
Reply 2 of 7, by MiniMax
Rank Moderator
Moderator
Not possible.
_________________
Reply 3 of 7, by HunterZ
Doesn't SDL have SVGALib support?
Reply 4 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
DOSBOX window is a graphic window. No way around it - even if you see just a DOSBOX command line, it is not text mode from the point of view of the host computer. So it cannot run in text mode!
Mirek
Reply 5 of 7, by HunterZ
I was under the impression that by "text mode" he meant anything but X-Windows. Linux has an API called SVGAlib that is used almost universally for non-X-Windows graphics. SDL, the wrapper library that DOSBox uses for graphics, supports SVGAlib (I think), so DOSBox should too. I wouldn't know how to make it work though.
There's also an extension to SVGAlib that makes it use text modes as graphical modes (I remember someone released ttyquake, a port of Quake 1 that runs in text mode), but that's another story and it wouldn't translate the DOSBox text modes to Linux text modes.
Reply 6 of 7, by MiniMax
Rank Moderator
Moderator
There is nothing wrong with your logic, HunterZ, but it leads to two philosophical questions:
1) If a tree falls in the woods, and there is nobody to hear it - does it make a sound then?
2) If SDL can do graphics without X11, but nobody knows how to make it do so - can DOSBox then run without X11?
_________________
Reply 7 of 7, by prompt
see './confiure --help' output from libsdl:
--enable-video-fbcon use framebuffer console video driver default=yes
--enable-video-directfb use DirectFB video driver default=no
--enable-video-svga use SVGAlib video driver default=no
--enable-video-aalib use AAlib video driver default=no
The SDL_VIDEODRIVER environment variable is used to select the driver.
