First post, by mkubiak402
- Newbie
I think i got lucky with this mainboard it had the Nicad and it starting to leak but I got it off and there was no board damage.
this is the setup...
64mb of FP Dram
upgraded the 128kb of L2 to 512kb
486dx2 66Mhz (sx955 write back cache) < I don't know how to enable this in the BIOS I think I have all the jumpers set right.. but it's not a big deal.
Sound blaster 16 CT2940 ordered a DreamBlaster S2 to plug in it it Thanks PhilsComputerLab
Trident PM-V513 TGUI9440AG (Vesa local bus) it has 1 mb of Vram but i am going to try to hunt down some chips to upgrade it to 2mb
2gb HDD and a CF card.
Things I still need are a HDD/FDD controller card and a 3.5 Drive Bay IDE to Single CF Adapter
Anyone have a link to the comport block of plates? if not i'll have to make some..
And i am trying to find a front mount CF or SD for the master slave setup what adaptors work better CF or SD? i'll have the 2bg hard drive as master and the CF as slave. If that drive dies i have had a lot of trouble with getting CF cards to work right in Master slave config.
for the write back cache it has CPU inter Cache policy i can't change that? is that the setting for the L1 cache?
DOS 6.22 FIC-486-VIP-IO AM486-DX2 66Mhz 64mg
Win98se MS-5169 AMD K6-III+ 450 @ 550Mhz 512mg Voodoo 5 5500.
Win98se GA-6VXE7+ Intel Pentium III 750 512mg Voodoo 5 5500.
Win XP MS-6712 AMD Athlon Xp 2700+ 2gb 6600GT
